Cleaning the Engine
Old Mar 21, 2007 | 04:14 PM
T-B_MN's Avatar
T-B_MN
Cleaning the Engine
Just wondering, whats the best way to clean the engine? Can i just spray the hose on it, or do i have to wipe the thing down with a wet rag? My engine is covered in dirt and grime, all that off roading doesn't help, and wanted to know the safe way to clean it. Help is appreciated. Thanks!!
Old Mar 21, 2007 | 05:27 PM
last5oh_302's Avatar
last5oh_302
I've always useed Simple Green. It's the lazy man way of detailing an engine. Spray it on, wait a few minutes and take the pressure washer to it. Brings it up just like new, and I've never had a problem. I even use it on my Mustang and I have a bunch of engine work done on it from intake, heads all the way down, other than block and pistons.
Old Mar 21, 2007 | 05:39 PM
wildcard30's Avatar
wildcard30
I agree with the simple green, but a pressure washer?
One oops and all of your electronics under the hood are wet. A pressure washer can drive the water into the connectors.
Protect your electronics with plastic bags, tape 'em up real good and use low pressure water.
Old Mar 21, 2007 | 05:46 PM
last5oh_302
lol... yes, full blast too!!
Obviously when I'm aiming the pressure washer I only give full blast exposure to the non electrical areas. The electrical areas get a blast but from more of a distance. All the electronics under your hood get wet anyway when you drive in rain.
Like I said, it's been working for me for years without complications.
Old Mar 22, 2007 | 06:35 PM
mattd17's Avatar
mattd17
what about the COP's on these engines??? i have been really wanting to clean my engine as well, but im afraid of ruining a 100.00 coil.
Old Mar 22, 2007 | 06:42 PM
last5oh_302
Don't drive it on rainy days
Old Mar 22, 2007 | 07:44 PM
Gparcels's Avatar
Gparcels
I just use Simple Green, just spray it on a cool motor, let sit for a minute then I just lightly hose it off. Usually I'll just run it to dry, if I really want to do a nice job then I wipe down all the plastic stuff to really make it look nice.
Old Mar 22, 2007 | 07:59 PM
patriots6800's Avatar
patriots6800
Gunk Foamy Engine Brite works great just spray it on let it sit and spray it off
Old Mar 22, 2007 | 08:27 PM
bridge's Avatar
bridge
Sick 'n Tired
Simple green and a low pressure mist wash. I usually check for any water pooling around the top of the engine afterwards and blow it out with compressed air. I'd stay away from high pressure washing. I've read dozens of posts here and on mustang forums where someone shorted out a COP or other under hood electronics.
Old Mar 22, 2007 | 08:35 PM
mattd17's Avatar
mattd17
where i live we average 13 feet of rain each year.... so there seldom is a day without something coming down. kinda sux !!!!
Old Mar 22, 2007 | 09:40 PM
subliminaldanger's Avatar
subliminaldanger
Make sure you look for pooling water, the sparkplug holes loves to collect water.
Old Mar 23, 2007 | 05:59 AM
last5oh_302
Yeah, if rain bothers it then it's not operating the way it should be. Perhaps I'm lucky, but with at least 5 different vehicles now, including my fairly heavily modded Mustang, I've used Simple Green and a power washer. I always get pooling around the spark plug holes as well. After a good drive and some engine heat build up, the puddling will dry up anyway, but again, I've never had an issue.
When I use the pressure washer, I don't get too close to areas that I would consider volatile. The volatile areas get the spray, but from a further distance.
Old Mar 23, 2007 | 10:34 AM
mattd17's Avatar
mattd17
last5oh302... i like the way you describe your mustang..... "fairly heavily modded".... i love the sound of the 5.0
Old Mar 23, 2007 | 10:51 AM
last5oh_302
Old Mar 23, 2007 | 11:16 AM
osteodoc08's Avatar
osteodoc08
For general cleaning I use Simple Green and the hose. I just make sure I don't hit the connectors with a blast of water. After it is clean, I let the engine idle for a while until it is dry. I then usually finish off with some type of plastic detailer and wipe it down. Never had a problem on any of my cars doing this. I usually do it when I wax. Every 2-3 months.
