1978 - 1996 Big Bronco
Front Oil Seal 86 302
Old 05-18-2002, 09:45 AM
cajunbronco's Avatar
cajunbronco
cajunbronco is offline
Old 05-18-2002, 12:25 PM
Pilotrick's Avatar
Pilotrick
Pilotrick is offline
Anybody know an easy way to replace the front seal? Motor less than a year old and front seal is puking oil.
Rick
86 302 EFI, bored 60 over, AOD,
Headman Headers, Flowmaster 40 series,
2 inch dual exhaust, MSD ignition
Old 05-18-2002, 09:20 PM
C Davis's Avatar
C Davis
C Davis is offline
[updated:LAST EDITED ON 18-May-02 AT 11:00 PM (EST)]Pilotrick,
I would assume, all new gaskets and seals were put on the newly rebuilt motor. If this is the case, and a new front seal was installed, the problem is not the seal, but a worn harmonic balancer.
You can buy a harmonic balancer repair sleave for probably less than 10 bucks.
The exact same thing happened to me. I rebuilt the 302 in my 83 bronco last fall, and everything ran great except I used a quart of oil every 500 miles. I found it to be coming around the front seal. An 18 year old kid at the parts store told me about the repair sleave. I wish I had known about this this trick before I assembled the engine. I can almost get to 3000 miles now before I am a quart low.
C.Davis
Old 05-19-2002, 12:17 PM
Pilotrick's Avatar
Pilotrick
>Rick
Well it was not the seal after all it was the oil pressure sending unit . It was puking out the end of the unit and dripping down the front cover making it look like the front seal. Speaking of the front seal I don't remember from when I rebuilt the motor, but can you replace it without removing the front cover :-X11 ? Chiltons says you can and Haynes says you can't which is right ? Thanks for your help
Rick
