New HELP
Old Mar 21, 2007 | 09:20 AM
dlaul01's Avatar
dlaul01
New HELP leak in oil pan
I have a 2000 i have rust on the oil pan it needs replaced i hear you have to take the engine out to replace this. Has anyone ever done this and what way should i go about it is there and easier way to do this?
Old Mar 21, 2007 | 10:27 AM
l-m tech's Avatar
l-m tech
if it isnt leaking then you can grind down the rust and apply a anti corrosion coting from ford onto the oil pan after cleaning.check out tsb 05-20-3
Old Mar 21, 2007 | 10:46 AM
dlaul01's Avatar
dlaul01
its leakin its bad it needs replaced
Old Mar 21, 2007 | 10:59 AM
AustinS's Avatar
AustinS
I'm afraid there is some heavy lifting in your future.
Austin
Old Mar 21, 2007 | 11:04 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
If your good at turning wrenches, it's not as hard as it seems. If it where me, I would do it myself.
Old Mar 21, 2007 | 05:11 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Check out this thread, it's just started but i think it might get longer as time goes on and people chime in-
https://www.ford-trucks.com/forums/5...-question.html
Old Mar 21, 2007 | 07:47 PM
Kwikkordead's Avatar
Kwikkordead
If it's only on the bottom you could patch it easy enough. I've often thought of hitting it with a wire feed if it's only got a pinhole.
Old Mar 21, 2007 | 08:49 PM
kennedyford's Avatar
kennedyford
Wait, where is it leaking from? The dip stick tube and running down or an actual hole?
