Need a answer fast
Old Mar 21, 2007 | 07:09 AM
ford_man's Avatar
ford_man
Exclamation Need a answer fast
I have a flatbed that I want to buy and I was wondering will it fit because it came off of a chevy, and I am wanting to put it on my ford truck.
Thanks
Ford man
Old Mar 21, 2007 | 09:33 AM
95Ford4x4's Avatar
95Ford4x4
need more info......what kind of truck do you have and what is the chevy????
Old Mar 21, 2007 | 10:22 AM
MustangGT221's Avatar
MustangGT221
A tape measure is your best friend in this situation.
Old Mar 21, 2007 | 12:03 PM
95Ford4x4's Avatar
95Ford4x4
most of those flatbeds are made by same company, whether they go on a dodge, chevy, or ford, so you should be able to do it, but i couldn't tell you what has to be done to go from one to the other.
Old Mar 21, 2007 | 12:05 PM
frederic's Avatar
frederic
The mounting holes might not line up perfectly, but you can drill through the top of the c-channel frame only and then bolt through and it is "mounted".
Then just fenagle the wiring and you're good to go.
I have a friend with a chevy cab on a F350 crewcab frame with a dodge bed - all leftovers from other things that have gotten wrecked and he combined them for one running vehicle. It's titled as a chevy
