carrier bearing condition
Old Mar 21, 2007 | 12:22 AM
skittlejr's Avatar
skittlejr
over in the thread about u-joints someone mentioned changing carrier bearing with driveshaft u-joints. how much, if any, play should/can there be with the rubber bushing around the bearing. if i push up on my driveshaft it moves a little-ok or not? seems to me like there shouldn't be. my experience with carrier bearing is on big military trucks and when they got play they started jumping around in there when the torque was on the shaft.
Old Mar 21, 2007 | 08:34 AM
tjbeggs's Avatar
tjbeggs
if the movement is between the metal strap and the rubber. replace it. if the little movement is in the corratgated rubber section your ok more than likely.
Old Mar 21, 2007 | 06:24 PM
powerstroked162's Avatar
powerstroked162
Sounds fine to me. Vibration under acceleration is a give away that its goin out.
Cowboy Steve
Old Mar 22, 2007 | 12:03 AM
skittlejr's Avatar
skittlejr
thanks. it can wait a few months, lots of other stuff right now...tires, shocks, tie rod. does it ever stop, lol
