Engine noise
Old Mar 20, 2007 | 10:51 PM
gsg1970's Avatar
gsg1970
Engine noise
The engine of my 01 F250 PSD makes a lot of racket when I take off. Specifically, it sounds 'clanky' and then as the engine warms up it is less so. Any ideas as to the problems?
Thanks.
Old Mar 21, 2007 | 02:07 PM
NYDieselDan's Avatar
NYDieselDan
Join the diesel world. There are a million avenues you can go down to help cure the rattle and noise these things make. I have yet to find a cure after half heartedly trying everything that doesn't require major surgury. I can tell you this, Cold air makes these things noisy, period. I think the northerners are the ones to always complain about it because 10 or 20 degrees makes a huge difference. The tuners turned up produce more noise and all the upgrades to the intakes and exhaust seem to make even more noise. See a pattern here, power improvements make noise. Invest in dynamat soundproofing if you want to help the cab noise. Thats my next move. Don't get me wrong, air in the fuel system and injector problems create more noise, but even at their best they are noisy.
Old Mar 21, 2007 | 03:00 PM
clintbonnie's Avatar
clintbonnie
Thanks.
Modifications you can make to the engine to reduce noise are:
1. install a HPX.. a high pressure crossover pipe.. about $50.
2. fuel line and intank mod's.. reduces the air in the diesel.
3. add some biodiesel.. i run about 2 gallons per tank..
4. change to synthetic oil .. i use shell 5w40.
You do a search in the forum for how to do the mod's.
But, yes your engine is going to noisey when cold until it warms up.
Old Mar 21, 2007 | 03:31 PM
Mike F250's Avatar
Mike F250
My truck is noisey when it is cold. It has 15 W40 in it from the dealer and I have not had to change it yet. Driving for a long period I noticed the engine does get quieter. Seems that it takes a while to warm oil and all.
Old Mar 21, 2007 | 07:06 PM
Kwikkordead's Avatar
Kwikkordead
What Clintbonnie said. Especially the first two items. It will make a vast improvement.
Old Mar 21, 2007 | 09:22 PM
gsg1970's Avatar
gsg1970
Thanks for the good info. This is my dream truck, I just do not want my wife to lose faith. I will work on the list from clintbonnie. I love my Ford!
