Sponsored by: Real Truck
Help with Codes
Old Mar 20, 2007 | 07:13 PM
rog2554's Avatar
rog2554
Exclamation Help with Codes
Need help, my 2002 F350 quit running yesterday? It lost power and then died while driving. Checked under the hood, it is leaking oil down the backside of the engine and there is oil in the valley of the engine. Checked error codes, there were two, P0773 Gear 3 Ratio error and P1211 Injection Control Pressure above / below desired.
<O></O>
I just installed the CCV mod on Sunday.<O></O>
<O></O>
2002, F350, 7.3, Banks Power Elbow, Banks 4" Exhaust, Edge Juice with Attitude.<O></O>
Old Mar 20, 2007 | 08:13 PM
Pocket's Avatar
Pocket
Check your HPOP o-rings, you might have one that let go and you lost most of the oil out of your engine. Did you check your oil level on the dipstick? The good thing about HEUI is that the engine will shut off long before the oil level gets critical enought to cause engine damage.
Old Mar 20, 2007 | 08:28 PM
tommyl's Avatar
tommyl
I dido what pocket says, if you lost too much oil the motor will shut down. Its happened to me (780000 mi.) still going strong today.
Old Mar 20, 2007 | 08:47 PM
rog2554's Avatar
rog2554
Yes Oil level was very low. What is the HPOP is that the Turbo Pedestal seals?
Old Mar 20, 2007 | 09:11 PM
rog2554's Avatar
rog2554
Ok now I know the HPOP is the High presure oil pump. I will check it Thanks.
