I have a 2001 Ford F-250 LWB Supercab. I installed go-rhino sidesteps a long time ago. I noticed on the go-rhino site they do not list any sidesteps past 2006. I would like to keep the siderstep bar - it's the stainless version and here is where I need some help from someone that has a 2008 Supercab.
The mounting hole on the sidestep are in pairs 3 inches apart. There is a set in the front on the flange under the truck. The first hole is about 17" or so from the tire. The matching hole is 3 inchs back from that. The next set of holes start 57" from the first hole. And the last hole 60 " from the first or 3 " further back. So 0--0-------------------------------------0--0
Could some brave soul take a look and see if the 2008 supercab has the same setup?
FYI - I did the simple thing and called Go-Rhino. Apparently they haven't changed much on their bars for a good while - they didn't even list the 2007 or 2008 vehicles.
Anyways, a rep told me that the sidebars on the 2001 SC LWB SD should fit the 08. He actually said the 99-08 should all be the same on the Supercabs.
