Floor board rust holes
Old Mar 20, 2007 | 05:22 PM
jostrowski's Avatar
jostrowski
I have two holes in my floor board. What is the best way to fis them? Just patch them? Or can I buy a new floor board and have that welded in? Where could I fine a good quality floor board that won't break the bank?
Old Mar 20, 2007 | 05:33 PM
77f-250HB's Avatar
77f-250HB
lmc truck or bronco graveyard
Old Mar 20, 2007 | 05:58 PM
clean79150's Avatar
clean79150
You can get new floor panels for about $40.00 a side at most salvage yards that sell repair panels
Old Mar 21, 2007 | 01:14 PM
trinogt's Avatar
trinogt
try crosscanadaparts.com
there is a US counterpart, but i forget the name. This will give ya an idea of price. Autobody supply stores should get you the same part. If i remember, each complete floor side was about $35. You can cut and weld or cut and glue in (with special adhesive) the new panel. If you don't have a welder, you can grind out the old panel, and cut new panel to overlap 1/2" to 1" all around, and drill some holes every couple inches around the perimeter to have a welding shop spot weld in place. Then you can apply seam sealer to the seam, let harden, and place carpet or mat back on. (factory uses seam sealer on all seams)
Old Mar 21, 2007 | 01:36 PM
MBBFord's Avatar
MBBFord
How big are the holes.
I had small holes in my floor boards, and I put POR 15 to stop the rust, and then used a epoxy puddy to fill in the small holes, and put a bedliner over it all.
Old Mar 21, 2007 | 03:59 PM
jostrowski's Avatar
jostrowski
One hole is the size of a football. The other is size of an apple.
