Headlight/Remote Door Lock
Old Mar 20, 2007 | 09:46 PM
campingpaul's Avatar
campingpaul
I am also interested in this. Especially when we are camping, the lights might be blasting into someone else's campsite at night. I would not like it if someone did it to me and I don't want to do it to anyone else. The cabin and rear lights are fine. I would prefer to disable the headlights from coming on. My explorer has lights under the mirrors. That is much less intrusive.
Old Mar 21, 2007 | 07:10 AM
FXForistell's Avatar
FXForistell
Originally Posted by kenwowski
mine only come on at night too is your truck and 07?
It's an 06. And thanks to all for the replies. As for the information center, that must be an option I don't have.
Old Mar 21, 2007 | 08:57 AM
Tom's Avatar
Tom
I think it has to do with whether or not your truck has automatic headlights. If it doesn't, it would have no sensor to tell it whether it was night or day. I'd imagine if it didn't have that, they'd come on all the time...
Old Mar 21, 2007 | 09:00 AM
FXForistell
If the sensor is that flashing red LED in the dash, then I have it. I need to go back to the manual and find out what the information center is.
Old Mar 21, 2007 | 09:02 AM
Tom's Avatar
Tom
Nope, the flashing red thingie in the dash is similar to what OTHER manufacturers(read: GM) use for a sensor, but ours have one above the rear view mirror. See the black wires going into your mirror? That should be it.
That red flashing thingie on the dash is the theft deterrent light. Supposed to look like the truck has an alarm or something...
I looked in your gallery, and you do have the autolamps, so you should have that sensor.
Old Mar 21, 2007 | 09:06 AM
FXForistell
I do have the mirror wire. So the red thingy is a fraud? Does it have any purpose at all other than screen door security?
Old Mar 21, 2007 | 09:11 AM
Tom's Avatar
Tom
Nope, don't think so.
It's like the blinking light on the instrument panel on my '03 F150 and my '05 Mustang...the manual says that it indicates that "the passive anti-theft is active". This just means that that the system which requires the programmed key to start the truck is active.
Useless!
Old Mar 21, 2007 | 09:20 AM
FXForistell
Wow. That's a big old lump of waste then.
Old Mar 21, 2007 | 09:29 AM
sammer4u's Avatar
sammer4u
I think the "red flashy thingy" is the sensor for light as well....
Old Mar 21, 2007 | 11:28 AM
Tom's Avatar
Tom
Nope, this is straight out of the 2007 owners manual:
Anti-theft indicator
The anti-theft indicator is located on top of the instrument panel.
• When the ignition is in the 1 (OFF/LOCK) position, the indicator will
flash once every 2 seconds to indicate the SecuriLock system is
functioning as a theft deterrent.
• When the ignition is in the 3 (ON) position, the indicator will glow for
3 seconds to indicate normal system functionality.
If a problem occurs with the SecuriLock system, the indicator will flash
rapidly or glow steadily when the ignition is in the 3 (ON) position. If
this occurs, the vehicle should be taken to an authorized dealer for
service.
Old Mar 21, 2007 | 11:41 AM
sammer4u's Avatar
sammer4u
I believe I read a forum here stating that to make the lights come on quicker in the automatic mode, you can throw a towel over the sensor in the corner. I have actually tried it with my hand to see if it works, and it does... With that being said, maybe they changed somehting for '07? (of course i can not find the forum that stated that now!)
Old Mar 21, 2007 | 12:29 PM
FXForistell
I don't want them to come on at all.
Old Mar 21, 2007 | 01:32 PM
  #28
double06's Avatar
double06
Well, I thought somebody would have hammered this one down by now but I see it hasn't been done. So, I got up just now and walked my lazy **** out to the truck to check the owners manual and sho nuff, page 91 (locks and security) has the steps to disable the feature that you all are talking about. I got an 05 manual. Somebody double check me real quick and lets see if we can lay this to rest.
Old Mar 21, 2007 | 01:34 PM
  #29
sammer4u's Avatar
sammer4u
I am glad you were able to do so, I am not able to till later tonight...
Hopefully this will help!
Old Mar 21, 2007 | 01:54 PM
  #30
FXForistell
Somebody buy this man a beer. The information is there indeed. It is on page 105 of the 06 manula but is there nonetheless. My error came from reading the keyless entry as the fob entry, which is not the same. Thanks for the good work double06.
