Welcome to FTE nissandoc.
Somebody will be along today who will know the answer to your delphi question.
Stancor relay: Have you seen Guzzle92's page? It has a big Stancor relay mod that I will be doing on my truck when the relay finally gives up.
I replaced mine about a month ago with Delphi. Easy install except for all the stuff you have to take off, that was a PITA but it does runs great. I got mine from www.mwfi.com for $30.31 a piece. Great service and shipping was on time. They even followed up with a phone call to ensure I got them.
Thanks Guys. I'll Try The Delphi Since They're A Little Cheaper. Bank 2 Is Dead So I,ve Gotta Do It. Thanks For Your Advice. Rumor Has It That Nissan Will Go Diesel In The Titan???? Even Though I Bust My Knuckles On Them Dailey, I'll Keep My Ford.
Update. Finished The Harness Replacement Yesterday. Went Ahead And Did Both Sides. Used The Delphi Harness. Did The Ccv Mod As Well. Used Guzzle92's Guidelines With My Own Little Twist,
Used A Vw Bug Pack Breather Kit. Ordered Stancor Relay On Ebay, $17.99 Wow. Dudes Name Is Woodcutter1979 And Had One Leftover At Auction End. Also Pulled The Trans To Fix Pump Seal Leak. She's Back To Normal Now. Thanks Guys. By The Way, The Bank 2 Harness Had Come Loose Inside The Valve Cover.
Update. Finished The Harness Replacement Yesterday. Went Ahead And Did Both Sides. Used The Delphi Harness. Did The Ccv Mod As Well. Used Guzzle92's Guidelines With My Own Little Twist, Used A Vw Bug Pack Breather Kit. Ordered Stancor Relay On Ebay, $17.99 Wow. Dudes Name Is Woodcutter1979 And Had One Leftover At Auction End. Also Pulled The Trans To Fix Pump Seal Leak. She's Back To Normal Now. Thanks Guys. By The Way, The Bank 2 Harness Had Come Loose Inside The Valve Cover.
That's a great idea!!!
Did you install the breather pipe in both valve covers and then to the central box as you would on a Beetle?
..........Ordered Stancor Relay On Ebay, $17.99 Wow. Dudes Name Is Woodcutter1979 And Had One Leftover At Auction End........
Be careful on some of the old stock on these relays. A few years back, Stancor had a wiring defect internally which caused the relay to burn out prematurely (or be DOA). Sorry I can't give you lot numbers or other info on these defective relays.
No. But I Wish I Would Have Thought Of It. Just Plugged Off The Extra Hole. Tried It First With The Steps Still On For The Lid, But I'm Gonna Go Back And Grind Them Off To Seal It. One Hose In And One Out. The Venturri Effect On The Hose Should Pull The Fumes Out When Rollin'. Used Coarse Steel Wool As A Filter. Shredded It So It Wouldnt Be Too Thick. The Dog House Has Steel Wool In It So I Dont Think Another Filter Is Really Nec.
