fluid change ?s
Old Mar 19, 2007 | 11:02 PM
mhannink's Avatar
mhannink
fluid change ?s
im looking to change all the fluids on our f450 psd. its got the 6spd manual and i think its the d80 rear end. anyways we are changing all the fluids and we need to know the size and type of oil thats to be used. im going to use redline if anyone has tried them and likes one of theres over the other im open for sugestions.
Old Mar 20, 2007 | 12:12 AM
jtharvey's Avatar
jtharvey
Have you checked the owners manual? It should state the specs and quantities for all of the fluids in the truck. I'm not trying to be a smart ***, so please don't take it that way.
Old Mar 20, 2007 | 07:08 PM
mhannink's Avatar
mhannink
i did look and didnt find it maybe im blind i dont know
Old Mar 20, 2007 | 11:55 PM
jtharvey's Avatar
jtharvey
No problem. I pulled my service manual, and here's what it says:
6 speed trans - 5.8 quarts of MERCON automatic trans fluid (not MERCON V)
Dana 80 axle - SAE 75W-90 QL synthetic gear lubricant - quantity not given, just to fill until it's level with the bottom of the filler plug hole.
Engine Oil - 15W-40 - 15 quarts
Engine Coolant - 33 quarts
Power steering fluid - MERCON auto trans fluid - quantity not given
Anthing else you would like for me to check, I can do.
Old Mar 22, 2007 | 07:47 PM
mhannink's Avatar
mhannink
thank you very much
Old Mar 22, 2007 | 07:57 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
If it is four wheel drive, the front axle takes 80w90 synthetic, and the transfercase takes about two quarts of synthetic ATF.
Old Mar 22, 2007 | 08:00 PM
mhannink's Avatar
mhannink
nope 2wd but thanks
Old Mar 22, 2007 | 10:06 PM
Mach1's Avatar
Mach1
Ford TSB the fluid in the Dana 80 to 85w-140...Syn of course..
