i usually hang out on the 48-60 side as i got a 55 but i just got a screaming deal 3 ford rangers , a 90 , 91 and 92 all short beds two with 4 poppers and an absolutely gorgeous xlt with a blown up 6 banger {the 91 } all for 500 or 250 for the 91 . i want to buy but i need some info on where to find the swap kits to put the slumbering 351 c-4 combo in my garage into the xlt . i know i bought a kit ages ago to put the 302 in my 85 but im gettin' old and the memory is going . whatever the co. was they had a kit also for a 460 swap that i later used to put my 429 in another one an 86 . can someone help??????
That lists some stuff for the swap, including mounts and headers. The mounts will fit either the 302 or 351, the headers I believe will, but I'm not 100% positive.
Either way, forget A/C, and if you remove the heater that would be a great benefit to space. The engine will just barely fit in with the heater in place, though you'll need to heavily notch the box. In addition, the steering will have to be redone under most conditions, and the oil filter moved.
Hi both my rangers I built off mre he has great pic on how to build your own mounts and verry good inst the book is 12.00 bucks
mre-books.com
go to v8 ranger
there are some sample pages that can be very helpfull
evan if you use other parts check this out it was very helpfull to me
