General Automotive Discussion
Methanol for emissions test?
Old Mar 19, 2007 | 09:23 AM
fred_79f250's Avatar
fred_79f250
Gentlemen,
Someone told me yesterday that if your vehicle is unlikely to pass an emissions test, just wait 'til your tank is half empty then fill it with Methanol. Car will run OK but it cuts the emissions drastically.
Never heard this before. Anyone else?
Thanks.
Old Mar 19, 2007 | 10:03 AM
Tedster9's Avatar
Tedster9
You want the engine to be running at peak efficiency - change the oil, tune it up (new plugs if necessary, 02 sensor,) and take it out for an hour or so cruise on the interstate prior to showing up to the testing station.
Old Mar 19, 2007 | 10:38 AM
fred_79f250
Ya, done all that. Just curious about this bizarre suggestion.
Old Mar 19, 2007 | 01:37 PM
rebocardo's Avatar
rebocardo
I know whatever they put in "Guaranteed To Pass" works, as I used that to pass my 1982 Chevy.
Old Mar 19, 2007 | 01:53 PM
85e150's Avatar
85e150
Methanol is kind of nasty stuff. Don't get any on ya. Might not be real friendly to your fuel lines and carb. See what it checks at before you take such drastic action.
Old Mar 20, 2007 | 09:38 AM
Bart99GT's Avatar
Bart99GT
Methanol is corrosive IF you use it for a long time. If you're just running a gallon of it mixed with 9 gallons of gasoline, I wouldn't worry about it.
However, pure rubbing alcohol is (stuff that's at least 90% ethanol) works just as well, without all the nasty side effects. Its enough to pass a car that barely fails, don't expect it to pass a vehicle that fails miserably and obviously needs repairs.
Old Mar 20, 2007 | 05:26 PM
Tedster9's Avatar
Tedster9
Just run half a tank of E85 if that's what you are after?
Old Mar 21, 2007 | 04:11 PM
Bart99GT's Avatar
Bart99GT
The only problem with E-85 is availability. Unless you're in the midwest, stations that actually have it are few and far-between. There are exactly 3 in Georgia right now, and all of them are over 100 miles from my doorstep.
Rushmore X
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Aug 6, 2017 10:40 AM
73fan
1997 - 2003 F150
Jul 5, 2014 01:56 AM
UNTAMND
18
Jun 12, 2014 05:51 PM
Choctaw Bob
Aug 14, 2008 11:14 AM
