Engine Performance
Old Mar 20, 2007 | 10:51 PM
Mil1ion's Avatar
Mil1ion
Have you looked in the FE engine forum or the performance forum ?
Old Mar 21, 2007 | 01:57 PM
C EVANS's Avatar
C EVANS
Idk i have not seen many around personaly. Yea right now i have post on the FE fourm
Old Mar 22, 2007 | 11:51 AM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Originally Posted by C EVANS
Okay some advice here. I have a 69 f100 with a 352 and i plan on putting some money into the engine to get some decent performance, any suggestions?
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.c...stributors.htm
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
Old Mar 23, 2007 | 08:08 AM
WillyB's Avatar
WillyB
Originally Posted by madax7869
the 352,360, 390, 428 are the same block . . . .
It is a lot more complex than that. Yes, the FE series used the same exterior mold for several years, (most had the infamous 352 number cast on the front) but they were cast different inside. Mostly it was the bore that changed - the cylinder walls are a bigger diameter on the larger engine.
But Ford used different cams, pistons, rods, cranks, even the webbing that supports the main bearings changed. There is a lot of parts you can swap around, but not all. Do it wrong and your engine is junk.
There is lots of information on what you can and can't do available - but the best is to find a machine shop that knows FEs and follow their suggestions.
Old Mar 25, 2007 | 08:06 PM
C EVANS's Avatar
C EVANS
Ha wait your saying all the FEs had the 352 number casted on the block?
Old Mar 25, 2007 | 08:39 PM
WillyB's Avatar
WillyB
Most of them - some of the later ones had a different number, but most did.
352 is a casting number - does not indicate machining. You will see the 352 number on engines from 330 to 428 cubic inches.
There are other olaces with a stamped number which helps ID the block. Check with the FE forum if you have more questions.
Old Mar 25, 2007 | 09:28 PM
C EVANS's Avatar
C EVANS
Okay thanks, but that means that the engine parts are atleast somewhat universal right
Old Mar 26, 2007 | 08:01 AM
Redcat Diesel's Avatar
Redcat Diesel
Yes the FE motors have a lot of interchangeability but as WillyB stated you have to be careful as some combinations just don't work.
In addition to the blocks cast with 352 many of the later blocks were cast with a mirror image 501.These were both production ( installed on assembly line) and service ( sold as replacement ) blocks.
Old Mar 26, 2007 | 08:44 PM
C EVANS's Avatar
C EVANS
So where can i find the numbers on the block to identify the actual size
Old Mar 27, 2007 | 12:26 AM
Danger_Dave's Avatar
Danger_Dave
69 F100
360 c6
i just installed a new msd blaster coil, same size as the stock one, but a little more juice i think, and now my truck runs like poop and i have black smoke coming from my exhaust. i thought maybe it was from the lack of a resistor like the directions say, but the parts guy at the store pulled up a microfiche and showed me that its not necessary and the wiring has it built in.
Old Mar 27, 2007 | 12:30 AM
Danger_Dave
[QUOTE=PerfDistIgnition]If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.com/forddistributors.htm[/QUOTE]
man i just took a look at those and i am thoroughly impressed. what would you recommend for my truck? 360, 2bl, c6, hooker headers, edelbrock air cleaner,
Old Mar 27, 2007 | 01:00 AM
Redcat Diesel
Down on the sides of the block.
Old Mar 27, 2007 | 12:41 PM
  #28
PerfDistIgnition
FTE Sponsor
[QUOTE=Danger_Dave]
We suggest part no. 33820 for the D.U.I.
If you want to maintain the stock Ford look, we recommend our Duraspark, part no. 33720.
__________________
FTE Sponsor
Old Mar 27, 2007 | 01:44 PM
  #29
Mil1ion's Avatar
Mil1ion
The difference between the 360 and 390 can only be done by measuring the stroke of the piston or by visually ID'ing the crankshaft marking.
They used the same block and different cranks.
as stated earlier. The Engine info is best asked or read in the FE forum.
Old Mar 27, 2007 | 03:23 PM
  #30
jowilker's Avatar
jowilker
Dennis Where you you think the FE forum crowd turns to to get the real low down on things? It sure as heck aint the diesel crowd, they come here.
John
