Spark plug suggestion.
Old Mar 18, 2007 | 08:58 PM
K.O-T.O's Avatar
K.O-T.O
I spoke to someone over the weekend, that works or did work for Ford, regarding the spark plug issue. I was told that Ford has stopped putting brake seeze on the threads of the spark plugs do to saving costs. If this in fact true then I'm goiing to remove them and lube up the treads, put them back in and replace them at the recommended 100k miles. Plus I just priced them at $12.97 per. and $7.97 for the originals.Just wanted to relay the message.
Old Mar 18, 2007 | 10:14 PM
Wilber15's Avatar
Wilber15
There's a reason for not putting antisieze on. It makes additional spacing between the plugs and the head causing them to loosen up. This in turn makes them vibrate and blow out of the head. which is what every person on here whines about. There is a reason dealerships don't use antisieze on plugs, so it's in your best interest you listen. Or don't bitch when your plugs blow out.....
Old Mar 18, 2007 | 10:21 PM
04 FX4 Lineman's Avatar
04 FX4 Lineman
I beleive he is refering to the issue of not being able to get the plugs out in 04 and up 5.4 engines, these plugs have 7-8 threads and won't blow out they come out very hard due to close tolerances in the heads and carbon build up.
Old Mar 18, 2007 | 10:31 PM
Wilber15's Avatar
Wilber15
Well if ford thought antisieze should be used, they would have put it in from the factory. No bulletin I know of said use antisieze. and every tech I work with never uses it. It also contaminates the plugs..... bottom line if ford certified techs don't use it, why would a home mechanic want to??
Old Mar 18, 2007 | 10:53 PM
edgl's Avatar
edgl
Isn't there a Ford TSB for putting nickel antiseize on new plugs when you replace them? So Ford does know that there is a problem with their plug design.
Old Mar 18, 2007 | 11:18 PM
johntucker09's Avatar
johntucker09
you don't put the antiseize on the threads though...you put the antiseize on the (insert word that i don't know) tube part of the plug...
Old Mar 19, 2007 | 12:43 AM
VFR_Man's Avatar
VFR_Man
Originally Posted by edgl
Isn't there a...
https://www.ford-trucks.com/tsb/full...hp?tsb=06-15-2
Old Mar 19, 2007 | 01:27 PM
04 FX4 Lineman
If you are really a ford tech you sure aren't reading your TSB's because that is exactly what ford tells you to do except not on the threads, plus I would not trust ford to do the right thing for a second!!!!!!!!!
Old Mar 19, 2007 | 02:51 PM
FS-150's Avatar
FS-150
This was posted in the 4.6,5.4L Modular Engine forum on this site referring to the 5.4L 3V engine:
NOTE
ONCE THE SPARK PLUGS HAVE ALL BEEN
REMOVED, NEW PLUGS SHOULD BE
INSTALLED USING A FILM COATING OF
MOTORCRAFT HIGH TEMPERATURE NICKEL
ANTI-SEIZE LUBRICANT (XL-2) ON THE GROUND
ELECTRODE SHIELD OF THE NEW SPARK PLUG
(FIGURE 7). DO NOT COAT THE ELECTRODE
STRAP OR THE PLUG WILL MISFIRE. THE NEW CONDITION PLUGS SHOULD BE INSTALLED WITH
NO LUBRICANT ON THE THREADS AND TORQUED
TO SPECIFICATION, 25 LB-FT (34 N•m).
Pretty much sums it up.
Old Mar 19, 2007 | 09:39 PM
Wilber15's Avatar
Wilber15
First off I'm not a tech(YET)....I'm an intern at a dealership. I'm still going to school for this. And everyone(including my teachers) tell me not to use antisieze on plugs. Secondly, I've never seen a 5.4L (that I can remember) that used the plug posted after your comment(with the extra spacing after the threads). Every plug I've ever used had the 7-8 threads then the electrode(which you can't use antisieze on these because it messes with the grounding of the plug as well as if it gets on the electrode will cause misfiring)or the old 3-4 thread used in the troubled heads..... I"m just going by what I"ve been told by techs with years of experience.
Old Mar 19, 2007 | 10:10 PM
Good Guy's Avatar
Good Guy
... Secondly, I've never seen a 5.4L (that I can remember) that used the plug posted after your comment(with the extra spacing after the threads). Every plug I've ever used had the 7-8 threads then the electrode(which you can't use antisieze on these because it messes with the grounding of the plug as well as if it gets on the electrode will cause misfiring)or the old 3-4 thread used in the troubled heads..... I"m just going by what I"ve been told by techs with years of experience.
THIS IS SCARY!!!! Check the plugs on any 2004 5.4 & newer..
Old Mar 19, 2007 | 10:16 PM
evl150's Avatar
evl150
If you've never seen a plug like that then you haven't seen or know much because that is the plug that the 3v 5.4l in the 04-up f150's use.Maybe you should pay more attention in class!!
Old Mar 20, 2007 | 05:38 PM
04 FX4 Lineman
Are you sure you work in a ford shop???? If so have one of those old techs with years of experience show you how to change plugs in a 5.4 3v with 50-60K and if he doesn't follow the TSB see how many plugs he twists in half, at your shop that may be what they want then can charge customer for new heads?????????
Old Mar 20, 2007 | 09:55 PM
K.O-T.O's Avatar
K.O-T.O
YO wilber, The Ford mechanic I am referring wouldn't have any reason to lie first of all. Second, your making comments with no proper backround other then being an intern and a student. You may want to get used to these plugs because if you pass, you maybe repacing these broken plugs.
Old Mar 5, 2008 | 04:18 PM
wesFX4's Avatar
wesFX4
Now anti-sieze at factory
Just to inform you, my truck has 50K ran premium gas, injector cleaner, fuel antifreeze the works, still one plug broke, the thread came out but not the electrode, since "spark plugs" are not under warranty, not even extended warranty, you have to pay for the head removal and cleaning which amounts to $2,600. Check with your intructors. The Service Tech at Ford's dealership has told me that now the "lubricant/anti-sieze" is being added at the factory, guess why? Too many complaints from customers being charged an arm and a leg for a factory problem. Mine is #4 broken plug this year, not including the ones that happen in the ford's shop.
