advice
Old Mar 18, 2007 | 07:26 PM
str8racing's Avatar
str8racing
advice
today i pulled home my new acquired enclosed trailer and about 3/4 of the way home the trans. started dripping from the rubber plug area where you drain the convertor also the fluid smells burnt. what should i try? can i save it?
Old Mar 18, 2007 | 07:59 PM
lostin90s's Avatar
lostin90s
Other than rebuilding it. I never had luck with them after the burnt fluid thing. I've replaced 12 of these trans over years. The front seal may be leaking . Bu if you pull to fix rebuild it. Try flushing it and new fluid might get more miles out of it might not. Good luck
