4X4 not engaging
4X4 not engaging
Just bout a 1990 F-150 XLT Lariat 4X4 and the four wheel drive will not engage. It shifts fine into 4 wheel high, N and low but the front wheels do not spin (hubs locked). I know there could be many differnt things wrong but if some of you have similar problems or solutions would be great.
Crawl under truck and have someone work linkage (if its a manual xsfer case) The shifter may be broke . (hope fully ) Next jack truck up and spin tire with hub locked in . If drive shaft turns Hubs and front should be OK. That leaves the transfer case Not much to em . I broke the one out in my plow truck yesterday . Goes down road just fine in 2x4 no noise but it just doesn't do anything in 4x4. It has to wait ti;ll snow melt(truck wont fit in garage. )
If its an auto case could be motor ,sensors , or a bad wire . Good luck
