Injectors/Pump
Old Mar 18, 2007 | 05:22 PM
dwkremer's Avatar
dwkremer
Injectors/Pump
91 F250 4x4 7.3 IDI 5spd 235,000miles
Dual 2.5 exhaust w/turbo mufflers, no soupbowl, dual ram air
How long do injectors and injector pump last?
How do you know if they need to be replaced?
I have had the truck since new, gets a solid 18mpg, same as when new when running empty.
However, mpg drops to 10/12 when hauling my 3,000lb cabover camper. When new I used to get 14/16mpg.
Any idea's?
Old Mar 18, 2007 | 05:41 PM
KJLYPW's Avatar
KJLYPW
Worn injectors do not pop, open at lower pressures, and don't close as fast as they should, resulting in higher fuel burn, and you will find the truck smokes more at idle than it should. Several threads here reciently on this subject. With those miles on original you can bet your due for new injectors, the pump doesn't owe you much with those miles either, but with fuel additives it could last a long time. Normally the IP will start leaking , you will see fuel in the valley below the pump, or timing seems to wander, or gets hard to start hot. These are sysmptoms I've seen posted here anyway.
Old Mar 18, 2007 | 09:18 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Modern fuel does not get as many MPG as the older fuel did.
If you replace the IP and injectors you may find you have more power and the MPG will probably increase a bit as well.
Old Mar 18, 2007 | 09:19 PM
dwkremer's Avatar
dwkremer
Thanks, I guess I'll start looking for new injectors and replace them this spring.
Does anyone have experiance with rebuilt injectors?
