351m valve rattle while excelerating
Old Mar 18, 2007 | 05:10 PM
FordCrazy1970's Avatar
FordCrazy1970
Question 351m valve rattle while excelerating
When I step on the gas pedal I can here a rattle and was wandering if the valves can be tightend or is it a lubercation problem? I dont want to lose my baby ,so any suggestions would be great on what to do.
1978 &1/2 f 150 ranger -explorer 351m c6 trany .
thanks,
Mike
Old Mar 18, 2007 | 08:30 PM
mercman78's Avatar
mercman78
are you sure it is a valve tick?it could be pre-ignition or what some people call pinging.this is common.have you ever tried a higher octane gas?there could be some carbon build up in the combustion chambers.or you could just have a stuck egr valve.check the plate under the carb(that is the egr).it should have a vaccume line comeing off of it,check the line for any leaks.check your timeing also.also check if the engine is running hotter than usual.
Old Mar 19, 2007 | 05:38 PM
FordCrazy1970
I'll check it out thanks.
j.g.curry
Jan 22, 2015 06:54 AM
78_f150
Nov 16, 2011 06:41 PM
FordCrazy1970
Jan 25, 2008 04:12 PM
damone
Jan 27, 2006 09:52 AM
stangman67
Dec 5, 2003 03:03 PM
