AC not cooling
Old Mar 17, 2007 | 11:47 PM
crustyeagle54's Avatar
crustyeagle54
AC not cooling
Just out of the shop last august new compressor and convert to r-134. now it wont cool . fuse is good but compressor wont start.Low on refrigerant? would like to at least diagnose it. Paid the Ford dealer 1400.00 dollars last august.Ouch!
87 full size Bronco 302.
Old Mar 18, 2007 | 12:47 AM
bustech81's Avatar
bustech81
You may be correct on a low charge condition. start your bronco and jump the pressure cycling switch on the accumlator and see if the clutch kicks in. if it does, than you need to put a set of guages on it to determine weather a bad switch or low on reefer. If not, than you have an electrical problem. check for voltage at the pump clutch. should be 12 volts. check this stuff first and if no luck, write back in, myself or some of the other guys would be more than happy to help you.
