Performance Problem- Help Please
Old Mar 17, 2007 | 08:42 PM
jncrgsc1's Avatar
jncrgsc1
My 99 Powerstroke sometimes misses, bucks, jumps soon after starting to accelerate. After about 1/4 mile it smoothes out and performs normally. It seems to only do this on startup(either warm or cold). I have changed fuel filter and Cam position sensor but still have the problem.
Old Mar 17, 2007 | 08:51 PM
Uzumati's Avatar
Uzumati
Any codes stored? how many miles since oil change and what type and level.
Old Mar 17, 2007 | 09:00 PM
jncrgsc1's Avatar
jncrgsc1
Have not checked codes yet. Engine light did not activate. Rotella 15W40, 2900 Miles.
thanks
Old Mar 17, 2007 | 09:06 PM
Uzumati's Avatar
Uzumati
does the tach drop when it happens like the classic CPS symptom. were all the terminals clean when you swapped it out.
Old Mar 17, 2007 | 09:11 PM
jncrgsc1's Avatar
jncrgsc1
Contacts were clean. I did not notice the tach, but I am sure it dropped since the truck almost stalled completely.
Does CPS problem normally throw a code?
Old Mar 17, 2007 | 09:16 PM
Uzumati's Avatar
Uzumati
they can but dont always trigger one (P0340, P0341, P0344)
Was that an OEM cps you replaced? I tried a carquest branded one once and it worked but through off the timing just enuff to cause problems.
Old Mar 17, 2007 | 09:20 PM
jncrgsc1's Avatar
jncrgsc1
Took out an OEM cps and put in a Borg Warner after market.
Old Mar 17, 2007 | 09:30 PM
jncrgsc1's Avatar
jncrgsc1
I am on a trip and 1500 miles from home so I guess I'll have to take it to a dealer for diagnostic checks YUK!
Old Mar 17, 2007 | 10:02 PM
Tenn01PSD350's Avatar
Tenn01PSD350
Where are you at?
Randy777
Oct 27, 2014 10:48 AM
Buck 1
Escape & Escape Hybrid
26
Feb 7, 2011 12:36 PM
jrz1
Nov 27, 2004 10:00 PM
jemcatman
Sep 25, 2003 01:11 AM
golfbum19
Feb 4, 2003 08:27 PM
