Is this PCM bad?
Old Mar 17, 2007 | 05:03 PM
goin4bro's Avatar
goin4bro
Exclamation Is this PCM bad?
I have a '95 7.3L that runs very, very rough unless it's warmed up & you're hard on it. I just got the AutoEnginuity w/Ford package and when I hook to this truck, it only lets me choose between "Generic Powertrain" and "Enhanced Powertrain" for the systems. If I choose Enhanced, it doesn't give me any sensors. If I choose Generic, I get a few dozen sensors; but when I monitor them with the motor running, the only one that seems to read correctly is the engine RPM. Throttle pedal reads 99%, Intake temp reads -40, Fuel pressure reads 110, Coolant temp reads 500.
Is this a bad PCM or a bunch of bad sensors? The RPMs tracking correctly is the only hint that the PCM might be OK. If the PCM is bad, is it time for a flash to fix it or a whole new unit? Should the "Enhanced Powertrain" system be showing me sensors as it does on my '99 7.3L?
Thanks in advance for your time - any help would be appreciated!!!
Old Mar 17, 2007 | 05:37 PM
tjbeggs's Avatar
tjbeggs
well I don't know anything about the auto enginuity other than I want one but I doubt your PCM is bad. is there a check engine light on? do you have a chip? oil level good? filter changed recently? Has this problem just started?
i would double check your connection to you truck and hopefully somebody familiar with AE will be along soon
Old Mar 17, 2007 | 09:03 PM
Cuda_jim's Avatar
Cuda_jim
I want one too, AE that is, here is a link to a forum just for AE users:
http://forums.itpdiesel.com/forumdisplay.php?f=49
Once you get the AE up and running right you'll find your trouble.
You could PM FTE user - amiller93 -he the AE guru on these forums.
Old Mar 18, 2007 | 08:39 AM
goin4bro's Avatar
goin4bro
Thanks for the replies...
No chip or check engine light. Oil is fresh, all fuses are good. Cleaned the PCM connector after killing power to it. I'm not sure how long it's been this bad. I just got it as the previous owner gave up on fixing it.
Battery voltage is low enough that I have to jump start it to get it to run. Once running, I connect the AE setup and it shows no codes at all.
For anyone who knows PCMs, is it possible for one to display these symptoms? IS it time for a new one or just a flash?
Thanks again - I'll hit ITP's forum...
Old Mar 18, 2007 | 09:05 AM
Cuda_jim's Avatar
Cuda_jim
These engines need a lot of voltage to operate correctly, even if the charging system is working OK. The IDM produces 110V DC to fire the injectors. You might need to charge the batteries and have them load tested. Clean and repair all the battrery and starter connections including the grounds, there are many. BAd grounds may cause some of the symptoms you described IMO.
mohrgg
Sep 10, 2016 06:25 PM
TSM35
Modular V10 (6.8l)
Jan 16, 2015 02:51 PM
jrjax
152
May 30, 2013 10:35 AM
countrycar
Nov 21, 2012 07:16 PM
surfnturf
16
Nov 25, 2010 04:56 AM
