I have 2wd ranger and after this winter I realized I need 4wd. Who converted 2wd to 4wd, I need you advice! any tips, please! What hidden problem will I get!?
Pablo-UA, Just curious, what country was your truck made in? Rangers have been made in USA, Brazil and Australia and somewhere else. They are not all alike in design but share some common components.
it is made in the USA truck, for US market (DOT aprouved headlamps and US engine calibrating).
As I've understood I need T-case + control unit, drive shafrts, but what parts I need for front end? Can I use Explorer parts available here, what years?
I'm really pretty sure that with the '98' and later Rangers, there is a difference in the width of the frame rails between the 4x4 and th the 4x2's. This might be a big pain to do the swap.
Dave
You would need to change the frame to get the front suspension attachments for torsion bar and front drive axle attachment as well as the steering gear attachment. You would be changing from a SLA 4x2 with coil springs to a torsion bar 4x4 suspension. I would have to agree it would be better to trade the truck for another one that is 4x4.
