1978 - 1996 Big Bronco
Negative battery cable
Old Jun 7, 2002 | 11:32 PM
rikfish's Avatar
rikfish
Old Jun 10, 2002 | 05:46 PM
macklin's Avatar
macklin
My battery cables are both worn out and need replacing. The positive cable was easy. Problem is the negative has the 2 inch lead on it. The cable I picked up at the store doesn't have the connector on the end of the lead. Can I splice and tape or is there an easier way about this. Thanks.
Old Jun 10, 2002 | 09:57 PM
Pilotrick's Avatar
Pilotrick
Just splice it together using a solderless butt connector and then use some heat-shrink to cover it up or good electrical tape if you don't have any heat-shrink. This will work fine. Make sure you do this good on my 86 that lead was the direct ground to the computer and I had all sorts of trouble when I forgot about it. I replaced the cables when I rebuilt my motor and I forgot about that stupid lead and I spent 2 days tracking down the problem. Good Luck,
Rick
86 302 EFI, bored 60 over, AOD,
Headman Headers, Flowmaster 40 series,
2 inch dual exhaust, MSD ignition
