I need some help for a buddy
Old Mar 16, 2007 | 07:24 PM
matt0588's Avatar
matt0588
I have a friend that has an F350 SC 4X4 7.3 AT production was 9/98 if that matters. 100K miles. he started it up and after a few minutes he said it made a click and shut off. would not restart. he had a friend with a scanner which was giving him unusual info. had rpm's while cranking so I didn't think it was the cps. his friend with the scanner hit the pcm a couple times with his hand and then the truck started and seems to be running fine. he is about to have his friend stick a new pcm in. does this sound right to you? any other ideas or things to check? thanks for any help you can give.
Old Mar 16, 2007 | 07:29 PM
redneckboy's Avatar
redneckboy
if he has any chip make sure it aint lose.
Old Mar 16, 2007 | 08:47 PM
John311t's Avatar
John311t
I second the chip idea if that chip comes loose, the pcm shuts down. Push it back in, and ur in business.
Old Mar 17, 2007 | 07:33 AM
matt0588's Avatar
matt0588
if it does not have an aftermarket chip, does it have an OE chip that may be loose? I told him that taking a running truck to the dealer and asking for them to find a problem is crazy. you might as well just give them your wallet.
Old Mar 17, 2007 | 08:10 AM
Uzumati's Avatar
Uzumati
Nothing in the PCM should click. I would check the power relays under the hood
