long crank
Old Mar 15, 2007 | 11:18 PM
mhannink's Avatar
mhannink
long crank
a month or so ago i replaced a 3 injectors. truck started great fired right off almost as good as a cummins motor. well now its back to the long crank its always had. my question is what could possibly cause a long crank. remember this has been the norm untill the injectors where replaced. so what might have changed besides the injectors that made it start so nice for a while
Old Mar 16, 2007 | 01:32 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Have you checked your HPO reservior checkvalve? IOW, does it do it only after sitting for a while but starts right off when warm? If so, let it sit overnight and pull the allen plug on top of the HPO and make sure the oil is within an inch of the top. If not, your oil is draining out of the HPO into the pan. Any other symptoms? Kind of a short post. How does it run/sound? How long did it start just fine before pooping out again and cranking long?
Old Mar 16, 2007 | 08:01 AM
Bossman7121's Avatar
Bossman7121
Mine just started doing that when sitting with a nose up incline. If it is the valve, is it hard to replace?
Old Mar 16, 2007 | 09:00 AM
justinthompson10's Avatar
justinthompson10
What if the oil is draining out of the HPO and into the pan?? Because mine has long cranks in the mornings or when it sits for a while, but it fires right up when it's warm...
Old Mar 16, 2007 | 01:14 PM
mhannink's Avatar
mhannink
ours cranks long anytime doesnt matter hot or cold after it sits or has just run
Old Mar 17, 2007 | 08:37 AM
Bossman7121
SO, I let my truck sit almost 24 hrs, and had a hard time starting her. It took almost 7 attempts to get it started on level ground, so I went looking for the hpop resivour allen key. Didn't have a socket set to remove the intercooler pipe, so I started to check everything else out. There is a fitting on top of the engine in front of the fuel filter with an electtrical connector on it, and it seems like it shoudl be snug, but is a little wiggly.
Next I found that both negative battery conncetions are not super tight, and might be lossening up, so I wiggled them a bit. Went to atempt to start one more time and it kick over instantly, as before it only cranked.
How can I accurately diagnose what is the real issue? It now seems it could be electical in addition to the hpop going bad, maybe?
Bossman
Old Mar 17, 2007 | 09:02 AM
Uzumati's Avatar
Uzumati
Assuming ther is fuel pressure 3 thinks need to happen to start a powerstroke
1. Battery voltage > 10.5vdc during cranking
2. Engine RPM > 100
3. ICP > 500psi (Injection control pressure - HPOP)
A good scanner will be capable of reading these PIDS
