Engine noise
Old Mar 16, 2007 | 07:02 PM
masterc16's Avatar
masterc16
Engine noise
Hi guys i can hear a nosie from my motor i thought it was the idealer pulley, but it turns out the belts is rubbing on the clutch fan pulley ,, i sprayed some wd-40 on the pulley when the motor was running and the noise went away for about 5 seconds. Is there anyway to adjust the belt so it doesn't rub on the side of the pulley ? I just changed the water pump to so i was wondering if the new pumps shaft is a little longer makeing the pulley rub on the belt ? any ideas ? thanks
