Sponsored by: Auxito
1998 heater core replacement
Old Mar 16, 2007 | 11:11 AM
Firemudder's Avatar
Firemudder
I have a 1998 f150 and the heater core has just went out and now I have to change it. I was wondering if there was an easier way of replace it without taking the whole dash out. Thanks.
Old Mar 16, 2007 | 12:07 PM
Silver Streak's Avatar
Silver Streak
There's not a better way, but the dash doesn't have to come completely out. You can drop the column, remove all bolts except one on the driver's side and just swing it out and set it in the passenger's seat. This saves a bunch of dealing with wiring, but there are still a few things that need done. Change the evaporator while you're in there.
Old Mar 16, 2007 | 04:05 PM
97fordf150's Avatar
97fordf150
http://my.voyager.net/~sscully/F-150...50_Exp_002.doc
Silver Streak is correct, Here's a link to step by step instructions that walks you through it.
Best of Luck
Old Mar 23, 2007 | 08:21 PM
Trevor1's Avatar
Trevor1
Hey, I am kinda new here, and I have a 2001 F-150 and the heater core went out on it. Well I have a freind that got me some instructions for a 1998 F-150 and how to fix it and all but we cant seem to get the damn dash outta mine. I need so links or a webpage or something for this guys. PLEASE HELP ME!
Old Mar 31, 2007 | 03:17 PM
okgearhead's Avatar
okgearhead
Exclamation heater core...
One thing you need to do is be sure to disconnect the shifter cable before you drop the steering column down, If not the housing on the cable can break, and you will have to replace it. Good luck.
