Installing a 4" lift
I am installing a 4" lift on my 90 Eddie Bauer and I have a few questions about some modifications that might be necessary. First of all will I need/or can I drop the steering stabilizer altogether in the front? Will I need a dropped pitman arm or can I use the stock arm already there? Will the driveshafts need to be extended or is there some kind of kit that I can buy to make up for the differences in length and angle. Are there any other modifications that will be necessary to complete the lift successfully? The kit came with blocks and U bolts for the back, extended radius arm brackets, front axle brackets (both sides), coil springs and hardware. I also ordered longer shocks separately. Any advice from those experienced in installing lifts would be greatly appreciated as this is my first. Thanks in advance!
KJ
I never used one. If you're running huge tires or bias plys it might be helpful. Really, a steering stabilizer is just a band-aid approach that masks other problems.
Yes.
No.
Just be sure you use the blocks AND the existing stock shims or you won't have enough pinion angle = vibes.
Jon
1989 F-150 XL- 4x4, 302, M50D
1995 Bronco Eddie Bauer- 351W, E40D
Finally got around to creating a gallery...check it out
1) drill off head to remove old bracket
2) Place plywood (3/4") pieces between the rivet and breakables (oil pan, tranny, etc.).
3) Use a .22 cal concrete nail gun centered on the rivet.
This is what I did. If you choose to do this it's your decision.
USE EYE PROTECTION AND BE CAREFUL!!!! The rivet will really fly out.
And probably the most overlooked but most important:
a REALLY good friend willing to spend countless hours under YOUR rig helping you.
Good luck
Steve
'91 Bronco
Eddie Bauer
351W 4x4 cam, headers, custom exhaust
6" Explorer Procomp lift
(Still waiting for the 35" tires
