351 pcv
Old Mar 15, 2007 | 07:36 PM
428fourby's Avatar
428fourby
351 pcv
Is there a trick to changing the pcv valve on a 95 351? Mine is to tight to the upper intake to get it out!
Thanks
Old Mar 16, 2007 | 09:49 AM
Jalon7's Avatar
Jalon7
The 90 degree fitting coming out of the valve cover will come out by angling it as you pull it out. My PVC was attached to the hose with a clamp. When I bought the new one I had to take the top connection part off to make it match the OEM part.
Old Mar 16, 2007 | 09:49 PM
428fourby's Avatar
428fourby
Ya, I thought the valve was the 90 in the valve cover, but it was a 90 a little further up that was a little easier to get at.
Thanks
