Remove gas engine, replace with diesel engine.
Old Mar 15, 2007 | 04:31 PM
watgad's Avatar
watgad
I have a 1988 single cab f-350 with 7.3 diesel engine. I also have a 1988 crew cab f-350 with a 5.8 gasoline engine. I want to remove the gas engine and replace it with the diesel engine. Is this procedure fairly painless, or are there complications between the diesel/gas exchange?
Thanks,
Watgad
Old Mar 15, 2007 | 05:28 PM
Winger235's Avatar
Winger235
This is fairly painless but will take some work. My strongest suggestion would be to pull the front clip it will make a huge difference of putting that heavy engine in a different engine bay. Check to see if your radiator support is the same as the donor truck. The 5.8L gas support will take the 37 inch 3 core radiator no problem but won't accept the 4 core. It won't even fit in the valley. Keep the wiring harness from under the hood from the diesel don't cut any wires tape and mark everything from where they came from. That harness will plug into the Gas trucks firewall plug and work fine that vintage was wired for both. You will have to take the saddles from the diesel frame for the motor mounts. They will match up with only 2 of the holes in the frame might have to drill out the others or they are already there. The diesel transmission will have to come with the diesel nothing from the gas will fit. Your drive shaft should be able to plug back in to whatever you have there. Gas tanks need to be purged but as far as holding and reading fuel it was the same system. I recently did one similar to yours it wasn't too bad just need and engine hoist and a truck load of ambition.
Old Mar 15, 2007 | 05:39 PM
watgad's Avatar
watgad
Thanks for the advice and tips. Does not sound impossible but it does sound challenging.
Watgad
Old Aug 5, 2021 | 06:56 PM
TowWrecker23's Avatar
TowWrecker23
Watgad
So revival of a dead thread? Less then a week ago I took on this same project, currently I have both engines (the 86 6.9 thats going into the 82 gas) removed and just waiting for my next days off to mount the diesel drive train in the gas... have you finished this build?! What were your biggest hurdles? So far mine had been determining if the engine mounts will just bolt up, or will work with minor fabricating.
Old Aug 6, 2021 | 12:35 AM
Charmalu's Avatar
Charmalu
The guy hasn`t been around since 4/6/16.
When you dig up an older thread, click on the user name
to see when they were last posting.
Charlie
Old Aug 6, 2021 | 12:45 AM
TowWrecker23
Charlie
I did notice that, I had just hoped the notification would maybe catch some of his attention? It doesn't work like that though does it...
Old Aug 6, 2021 | 02:46 AM
Charmalu's Avatar
Charmalu
Each time you check into the Forum, it records it.
Winger235 makes it seem pretty simple to do the swap
from Gas to Diesel.
Charlie
Old Aug 7, 2021 | 07:46 AM
tjc transport's Avatar
tjc transport
i ain't rite
he would only see if someone responded to the thread if he had email notifications turned on.
TowWrecker23
82
Dec 2, 2023 11:47 PM
00blkexplorer
Aug 19, 2009 05:01 PM
Greg H.
Sep 18, 2007 08:51 PM
thelonewuf
Apr 7, 2006 12:53 PM
