door ajar/dead battery
Old Mar 15, 2007 | 09:10 AM
jawdoc's Avatar
jawdoc
Recently I posted a question regarding the door ajar indicator staying on. I did the WD-40 trick and it worked like a charm. I replaced the battery because it was dead from having the dome light on chronically. Now there is no more door ajar and the dome lights go off when they should but now my new battery is dead! I have a short somewhere. My rear wiper quit working so Im suspecting that. Any hints?
Thanks
Dave 2003 Ford Expedition Eddie Baur
Old Mar 15, 2007 | 11:05 AM
heterodox1's Avatar
heterodox1
Put an amp-meter on the battery and start pulling fuses, one at a time; this should help narrow it down...
Old Mar 15, 2007 | 11:12 AM
jawdoc's Avatar
jawdoc
ok ill give that a try thanks
Old Mar 16, 2007 | 06:54 AM
gdub520's Avatar
gdub520
dead wiper aside have you ruled out bad alternator?
Old Mar 16, 2007 | 10:25 AM
jawdoc's Avatar
jawdoc
I havent investigated the alternator yet but the battery seems to be fine while running and operating all the electronics in the car, but it is dead in the morning when I go to start it.
Old Mar 20, 2007 | 01:17 PM
Sweetpea02's Avatar
Sweetpea02
My rear wiper stuck twice this winter because of too much snow load.
Both time the truck needed a boost the next morning. I just put the wiper on and off
and manually moved the wiper to its correct resting place and no problem since.
I think there is a battery saver in the Expy so when the drain get to s a certain point
the computer shut every thing down.
I think your problem is related to the rear wiper problem.
Old Mar 21, 2007 | 03:28 PM
jawdoc's Avatar
jawdoc
I agree. I just disconnected the wiper motor and Ill check it tomorrow. Incidentally the wiper motor was warm while it hadnt benn running at all.
DAve
Old Mar 21, 2007 | 09:57 PM
Sweetpea02's Avatar
Sweetpea02
I think that even if the wiper is not working, the motor is trying to complete its cycle to the proper resting place.
But I don't understand why it does not cut the power to the wiper motor when the key is turned off.
Old Mar 22, 2007 | 10:33 AM
jawdoc's Avatar
jawdoc
This morning the truck started just fine. Disconnecting the wiper motor did the trick (I hope). Now to get a replacement.
Dave
Old Jun 12, 2007 | 08:05 PM
Dogger16's Avatar
Dogger16
Okay I've got the spraying the WD 40 in the door locks for the "Door Ajar" light staying on but do you spray the door handle too..??
Old Jun 14, 2007 | 06:24 PM
Dogger16's Avatar
Dogger16
Thumbs up Door Ajar Light
Hey I did the WD 40 deal and it worked great for me......here's to a few more months of "door ajar" light staying on..!! I sparayed directly into the door handle on the outside while it was in the opening position all over and it worked right away...!! Thanks for the advice..!!
Old Jun 15, 2007 | 08:09 AM
tommy k's Avatar
tommy k
How did you disconnect the rear wiper?
Hi there,
Oddly enough, my battery on my 03 expy was dead yesterday morning. Put a charger on it and it was kaput, would not take a charge. So I put a new battery in, and read this thread.... whereupon i noticed that my rear wiper was not in the proper resting place. weird. So, untill i can figure it out, How did you disconnect the rear wiper motor? (the fuse runs the front wiper moter and instrument cluster, so that is not an option, right?)
Best regards,
