96 running rich
Old Mar 14, 2007 | 10:35 PM
Shanemh's Avatar
Shanemh
Question 96 running rich
I got an interceptor gauge for my 96 F150 with a 351W. I pulled a codde that says system running rich. I have had bad idling surges also where she revs down and splutters like shes gonna die then back to normal. Could the rich running cause this and how do I fix this problem.
Thanks, Shane
Old Mar 15, 2007 | 07:17 AM
Conanski's Avatar
Conanski
What code did you get?
Old Mar 15, 2007 | 11:47 AM
quicklook2's Avatar
quicklook2
check air cleaner and plugs.
Old Mar 16, 2007 | 09:00 PM
Shanemh's Avatar
Shanemh
The code I got was P0172. When I got in touch with Aero force they told me this code meant system was running rich. When you say check air cleaner is this the air filter and by plugs, is this refering to spark plugs? If this is the case, summit offer a tune up kit with spark plugs, wires etc, and I might get this. It sounds like a good deal, anyone know about it????
http://store.summitracing.com/partde...5&autoview=sku
Old Mar 16, 2007 | 10:25 PM
quicklook2's Avatar
quicklook2
do not buy that, it is overkill and overpriced.
do not go to autozone either.
first, check air filter and replace it if it looks dirty.
second, remove one spark plug and see if it is fouled.
if you do replace plugs use motorcraft resistor plugs, no platinum anything.
do baby steps, not throwing parts that you do not need at truck ***** nilly.
soak plugs with some rust penetrant before removal.
do not break any off.
if in doubt use a shop, but you supply the plugs.
get a manual if you do not have one.
Old Mar 16, 2007 | 11:45 PM
Shanemh's Avatar
Shanemh
Thanks for info, I have a K&N air charger filter with about 5000 miles on it so thats ok. Why not platinum plugs?
Thanks, Shane
Old Mar 17, 2007 | 11:04 AM
quicklook2's Avatar
quicklook2
are you sure that you oiled the filter correctly?
regardless, pull it out and look at it.
no platinums because you do not need them, these trucks like the good old stuff.
if you get wires ger motorcraft.
if you need a cap/rotor get motorcraft.
i will bet your air filter is the problem and than the plugs fouled up because of lack of air.
Old Mar 17, 2007 | 11:39 AM
92F150Flare's Avatar
92F150Flare
K&N's are oiled when you get them if you bought a new one.....You just plunk it in and enjoy it for the first 100k...or so.......then you might have to clean and re-oil.
There is another thread about running rich with a bunch of other suggestions too....look up the page.......it's titled "oxygen sensor" I think
Good Luck
Old Mar 17, 2007 | 12:07 PM
quicklook2's Avatar
quicklook2
depending on where you live the element should be cleaned way before 100,000 miles.
that is just propaganda advertising.
Old Mar 17, 2007 | 12:19 PM
92F150Flare
I agree......real dusty and dirty needs cleaning long before.......I always think in clean, and sterile ways......never have dirty thoughts.......i used to....but now i can't remember why......hehe
Old Mar 17, 2007 | 12:23 PM
quicklook2's Avatar
quicklook2
i am suggesting starting checking simple things first, he did not say it posted a code for o2 sensor and it is a 96 so he has obd II.
Old Mar 17, 2007 | 12:27 PM
92F150Flare
you're right quicklook2........i was just offering other options........It's always best to start with the simplest and least costly......I couldn't agree with you more.
shane4585
Oct 4, 2010 03:27 AM
BigCrzyRdNeck
43
Aug 30, 2010 07:03 AM
Rich Wood
May 12, 2007 04:24 PM
ford390gashog
Sep 10, 2004 07:30 PM
SHANE_2
Kansas Chapter
Aug 17, 2004 08:24 AM
