?? Mystery Features ??
Old Mar 14, 2007 | 09:54 PM
FXSTC's Avatar
FXSTC
Question ?? Mystery Features ??
I've had my truck for 5 days now and I LOVE IT!
But, being a used truck there are a few things I can't quite figure out on it and am hoping some of you grizzled old timers can help.
1. This is what my air filter/housing looks like:
Aside from the duct tape is this a normal stock filter housing?
2. Here is a "mystery button" on my dash:
Does anyone have any idea what this is? It isn't actually a button- it is solid; it doesn't push in.
3. "Roll-a-long". Here are three green buttons:
Any speculation as to what they do? Are they lights? Oil slick emitter? Radar jamming device? Ejection seat control? Submarine mode activator? Invisible mode? Fat-chick force-field switches?
Any help would be appreciated!
Thanks,
JK
Old Mar 14, 2007 | 10:29 PM
fishmanndotcom's Avatar
fishmanndotcom
1) yes stock air box.... cut it all out and run ya a napa 6637 filter!
2) dont have a clue! can you get a pic from a different angle maybe? any wires come off it?
3) i guess you havent *clearing of throat* TRIED them? lol. could also be a special lighting setup for a trailer the guy had since he has a brake controller i see.
-cutts-
Old Mar 14, 2007 | 10:40 PM
ech0sh4y's Avatar
ech0sh4y
I believe those green buttons do all of the above if pushed in the right sequence... My truck wasn't as fancy and as it did not come with the fat-chick force field or the Submarine mode activator... i talk only from experience =(
On a serious note: 1) ditto to fishmann 2) take it out and see if ur truck runs =D
Old Mar 14, 2007 | 11:30 PM
DAVID'S97F250HD's Avatar
DAVID'S97F250HD
That air box is the funniest thing I've ever seen, also the saddest, replace that thing before you drive it anyfurther.
As for the other 2 pics, those are aftermarket OEM additions :P and know idea what there for.
EDIT: take a test light and check to see if he has added some options at your trailer plug.
Old Mar 15, 2007 | 06:40 AM
Cuda_jim's Avatar
Cuda_jim
The real sad part about that stock filter box is the air deflector is missing. It mounts over the battery and takes in cold air from the front of the truck. I would try to get this part and install it if you can find one.
Dump that OEM filter box ASAP.
Search this forum for '6637' or 'kwik filter' for a ton of info.
Old Mar 15, 2007 | 07:13 PM
IDMooseMan's Avatar
IDMooseMan
Well, I agree with everyone about #1 (stock air box) and #2 (mystery button...no clue).
As far as #3, they look like they would activate additional lighting. Since you're not sure what these switches do, should we assume you don't have additional or aftermarket lights attached at various locations on your truck's exterior?
Old Mar 15, 2007 | 08:50 PM
FXSTC's Avatar
FXSTC
Thanks for the replies.
I Bought a 6637 filter today and will get the 4" 45 degree elbow Friday to complete the intake enhancement. I took the air-box off this afternoon just to take a look and it really is a mess. The truck is in such excellent condition I wonder why the air-box is wrecked....
I'll try to track down the wiring for the mystery button on Saturday. It's just such an odd thing- it almost seems like there is something that would press up against it- maybe something magnetic.
As to the switches- there are lights but when I played with them nothing came on. That, of course, begs the question- how do I get the lights on? Maybe these are the switches and there is simply a fault somewhere.
Thanks,
JK
Old Mar 15, 2007 | 10:34 PM
F350_Hauler's Avatar
F350_Hauler
Man, That truck is clean. Nice catch.
Old Mar 16, 2007 | 08:23 AM
Goober1979's Avatar
Goober1979
Could the mystery "button" be the OBDII port. Wasn't it located under the column before '97?
Old Mar 16, 2007 | 09:10 AM
walt1968's Avatar
walt1968
Right side in front of the passenger on my '96
Old Mar 16, 2007 | 04:07 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Exclamation
I notice that your wonderful truck has fog lights, haw do you turns on it?, or the switches are (one at least) for that?
just thinking
may OBDII is in the left side underdash.
Old Mar 16, 2007 | 04:10 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Edit: I mean righ side
Old Mar 16, 2007 | 07:05 PM
m14dan's Avatar
m14dan
I've got a stock air box lid and intake tube you can have for the cost of the 2 new screws I just put in it. I go the updated hold down screws from ford.
I took it all out and put a big filter in it that can withstand these dust storms.
How's it run ?
I only got mine a couple months ago and love it so far.
Old Mar 16, 2007 | 10:12 PM
miker67's Avatar
miker67
That looks like the OBD II port to me, try pulling out on the outer portion. Some of the ports had little dust covers on them. The plug part is underneath.
Old Mar 17, 2007 | 01:08 AM
skittlejr's Avatar
skittlejr
great looking rig
definitely shaped like an obd II port. look into that.
air box=the duct tape is there so all the dirt that the nasty fram filter lets through will stick to the tape and not wipe the turbo. came out in a tib a while back
but seriously-i would think the switches would have to go to lights. get the multimeter/test light out and see what you can find. are those lights on the running boards too...?
