holley 6919 tuning
Old Mar 14, 2007 | 09:47 PM
exploderjoe's Avatar
exploderjoe
holley 6919 tuning
I have a holley list 6919 on my 85 460, this carb has the reverse idle system. I have the idle mixture screws all the way in, which is were I have the highest vacuum reading and the engine still idles slightly rough. It seems to me that I am running lean. What jet size do I have now? and how many sizes should I go up?
Old Mar 14, 2007 | 10:26 PM
LxMan1's Avatar
LxMan1
Well, It came with 622 jets. Which are emmisions exact sized 62 jets.
I would try 65 jets. But I don't know if this will help the idle. How does it run other than a rough idle? I am guessing you have checked everywhere for a vacuum leak. What intake manifold do you have?
Here is the Holley link for carb info http://www.holley.com/data/TechServi...%20Listing.pdf
Old Mar 14, 2007 | 10:57 PM
exploderjoe
I just switched to a Edlebrock performer manifold after having problems with vacuum leaks with the factory manifold,the roughness it smoooths out as the rpm's increase and if I stomp on it, well it will pin you back.
on my vacuum gauge I have a high and fairly steady reading
Old Mar 15, 2007 | 12:24 AM
LxMan1's Avatar
LxMan1
Pull the spark plugs and see how they look. Black from too rich or white from too lean.
Old Mar 15, 2007 | 06:53 AM
exploderjoe
they are white
Old Mar 15, 2007 | 07:12 AM
LxMan1's Avatar
LxMan1
Try stepping up to 65 jets.
Old Mar 18, 2007 | 12:41 AM
kermmydog's Avatar
kermmydog
You are aware that the reverse idle carbs adjust the opposite of a regular Holley. The adjustment screws adjust bleed air rather than fuel. When you turn the screws in you richen mixture.
I assume you already knew this. I just thought I would mention it in case you didn't.
Old Mar 18, 2007 | 11:16 AM
exploderjoe
I stepped up to 66 jets by swapping a diffrent carb on to the engine I am going to be checking the plugs today to see if there was color change, but I still have a slightly rough idle
Scrappy6919
Nov 10, 2016 10:51 PM
Dot Heton
Apr 15, 2016 11:27 PM
HarlanThomas
15
Apr 9, 2010 02:10 PM
GQROD
Jan 1, 2010 03:36 PM
fdude64
33
Apr 24, 2008 07:33 AM
