right directional will not lock into position
Old Mar 14, 2007 | 07:08 PM
X36's Avatar
X36
Hi I was wondering if anybody had any opinions or info.I have a 78 f250 with tilt that I just bought.When I pull down on the blinker lever the lever will lock down and stay on.When I raise it up for the right signal It will not lock into position I have to keep the signal on by holding the lever up.Will replacing the blinker cam fix this or will I likely need to go deeper(parts wise) into the column Thanks
Old Mar 14, 2007 | 07:17 PM
orgblsmspcl79f150's Avatar
orgblsmspcl79f150
you should be fine by just replacing the blinker cam. it is a fairly easy job to do too the only real specialty tool you will need is a steeringwheel puller and it shouldnt take more than an hour to do good luck
Old Mar 14, 2007 | 07:30 PM
Mil1ion's Avatar
Mil1ion
The locking clip on the one side is broken.
http://info.rockauto.com/RB/Detail2....p1/5049304.jpg
