fuel pump: need some info
Old Mar 14, 2007 | 04:18 PM
tony b's Avatar
tony b
Hey guys. I have a 90 f150 4x4 4.9 with dual tanks. The front fuel pump went on me today. I also have a fuel transfer problem. When I run off of the rear tank it fills into the front tank so I am kinda forced to fix this problem now. I learned on this form that my transfer problem was the valve in the front tank is this right? Is there any way I can bypass the front tank for now ,like an in line check valve or something ? So I dont have to replace the front pump right now. Funds are kinda low right now. Also when I do replace the front pump is it worth pulling the bed since I also have some exahust work that needs done. I have heard people on this form say it was worth pulling the bed to fix the fuel problems. Any input would really be appricated thanks guys
Old Mar 14, 2007 | 06:29 PM
Tdvjensen's Avatar
Tdvjensen
Since you have a problem with the tank that you want to fix the pump in and seeing as its full now, I would pull the box off, but I have a forklift, spreader bar and numerous slings. Drain the tank first before messing with it if you are going to leave the box and pull the tank, because its a PITA empty never mind full. From what I have heard on this sight there might have been a recall on this problem that had something to do with a check valve etc, but I doubt ford would fix it now. I am sure that someone else had dealt with this exact problem and have some opinons and insight.
Old Mar 14, 2007 | 06:43 PM
subford's Avatar
subford
Yes more than likely.
If you can find and old pump (fuel delivery module) some place (salvage yard?) cut off both lines coming out of the pump and have someone (you?) weld the ends closed. Take off your lines and snap the plugged lines in their place.
Here is a diagram of your fuel system:
http://i54.photobucket.com/albums/g9...FielSystem.jpg
