Valley Pan
Old Mar 14, 2007 | 03:22 PM
4starcstms's Avatar
4starcstms
Valley Pan
Okay I just swapped cams in my 390, and got the motor reassembled cleaned, and painted (see the 73-79 forum for photos) but it was late and I was in a hurry when I dropped the intake on, and didnt install the valley pan, is this something that really HAS to be there or will I be okay without it?
Old Mar 14, 2007 | 08:57 PM
acheda's Avatar
acheda
One of the things the valley sheet metal does is to keep oil off the heat riser part of the intake. There is also a small sheet metal shield attached to most manifolds right under the carb, but the passage runs all the way across the manifold. Oil that splashes on the hot parts of the manifold "cokes" in to carbon deposits which slowly build up. I do not think this will cause much serious problem in the short run, but eventually it will get into the pan.
I think you can get by, but will be interested if anyone has anything else to add. (I'll bet this piece is left out on purpose by many mechanics that do not like "extra parts".)
Old Mar 14, 2007 | 10:31 PM
4starcstms's Avatar
4starcstms
Nobody else???
Old Mar 14, 2007 | 10:35 PM
Redmanbob's Avatar
Redmanbob
I'd say depending on use you may want it in there. 4 wheeling, traffic, slow high temp use will probably end up being an issue. Highway miles at smooth temps probably ok for a while ? Not sure really but ...it was there for a reason. And mine was covered in crap I thank god was not in the pan/bearings/oil galleries/etc...
Old Mar 15, 2007 | 01:48 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Eventually the oil will coke up, should small particles break off and go downstairs the oil filter will collect them so bearings will be fine.
The oil pump will be the one that will get the damage from crunching
up those particles.
Back in 69 I finished an all night assembly then went to bed, later that morning dad placed the valley heat shield on top of the engine stand for me to see. Made me feel bad as dad always waited for me to screw up (again) as this was his replacement motor, I blew the last one up and it was dad's truck.
Now this was without bier.
Old Mar 15, 2007 | 03:11 AM
dffay's Avatar
dffay
Do it to keep the intake cooler. Cooler air means a denser charge into the chambers. Its not going to be any easier to do than it is right now.
Old Mar 15, 2007 | 03:21 AM
4starcstms's Avatar
4starcstms
I guess I'll cut the intake off.. Heres why im really not wanting too:
http://usera.imagecave.com/4StarCstm...r/IMG_4020.JPG
Old Mar 15, 2007 | 05:47 AM
66 POJ's Avatar
66 POJ
Don't they look good before they start up! Nice lookin motor! Just finished mine and she is sweet lookin to.
Old Mar 15, 2007 | 06:12 AM
acheda's Avatar
acheda
Beemer has jogged my memory. His logic is correct - the problem is that the oil pump does have a "first-line of defense" against these particles: the pickup screen, which passes particles small enough for the oil pump to "crunch" and stops those that are too big. The problem is that, after a while, the big particles clog the pickup srceen and this is NOT GOOD! I have seen such screens & you don't want one.
Now you have a good reason to pull that manifold (+ all those pushrods).
Old Mar 15, 2007 | 10:17 AM
4starcstms's Avatar
4starcstms
pushrods arent installed.. just the intake, i hadnt gotten that far, wanted the intake on so we could paint it...
Old Mar 15, 2007 | 11:04 AM
"Beemer Nut"
Ten to one better now on a dry motor than with it complete under the hood with anti-freeze, oil and dirt. Looking pretty doesn't help it run any better before you have problems later on.
Old Mar 15, 2007 | 11:08 AM
arctic y block's Avatar
arctic y block
Why Cebby red instead of Ford Blue?
Old Mar 15, 2007 | 07:01 PM
"Beemer Nut"
arctic; I was waiting for someone to ask that same paint question.
Maybe if the motors installed backwards for the dizzy in the rear it will look normal.
Hey arctic, I got ya beat in age by exactly two months to the day.
Old Mar 15, 2007 | 07:24 PM
arctic y block
Cool Beemer. So are we 54 or 55. I been confused since I was 53. Seems like I been 54 for two years. HAAA. Gotta lay of the Wacky Weed.
Old Mar 15, 2007 | 09:15 PM
Hypoid's Avatar
Hypoid
Man! A guy just can't catch a break around here!
OK, OK, so he understands the correlation between color and power, and he didn't want to suffer the same fate as Burg460 (56K beware):
http://www.rmftc.com/forums/showthread.php?t=3353
I don't blame ya there Scott. If it's running just long enough to get on and off the trailer at a show or two I wouldn't think twice about it. At that rate you'd be doing something else with it next winter anyway. LOL If you want to drive it...now is a good time to fix it. Somehow I think you'll do fine with the touch-up.
