Installing a Techometer
Old Mar 14, 2007 | 01:35 PM
turboman24's Avatar
turboman24
Question Installing a Techometer
I am trying to install a Stuart Warner tachomter on my 1984 F-250 Diesel. It recieves a signal from the pulses coming from the alternator. The man from Stuart Warner told me to hook up the sender to the "R" Terminal on the back of the alternator. I also read in the instructions that is says it will either work on the "R", "W", or "AC" terminals. I do not have any of these terminals on the alternator. The man said that if there is not one that i have to get on installed. I was wondering if any body has installed a tach on their 6.9 with an alternator pickup if you could give me some info on how it was setup.
Old Mar 14, 2007 | 08:00 PM
Winger235's Avatar
Winger235
Try your voltage regulator on the inner fender passenger side. Should have 4 terminals and be labled with what you need.
Old Mar 14, 2007 | 09:32 PM
David85's Avatar
David85
Is it possible to pull a signal from the alternator for a factory non diesel tach?
Old Mar 14, 2007 | 10:52 PM
Dave Sponaugle's Avatar
Dave Sponaugle
The factory tach picks up it's signal from the IP drive gear cover mounted tach sending unit.
Old Mar 14, 2007 | 10:55 PM
dwaymar's Avatar
dwaymar
voltage rg has 4 term but only three are used
Old Mar 14, 2007 | 11:13 PM
David85's Avatar
David85
actually I was hoping to figure out a way to reuse the stock tack in a ranger that I recently converted to diesel.
Old Mar 15, 2007 | 10:07 AM
turboman24's Avatar
turboman24
Thanks for the info. Does the voltage regulator sit right next to the battery on the passanger side? I think i know where it is but your saying it will have the "R" terminal to pick up a feed from the alternator?
Old Mar 15, 2007 | 10:35 AM
davE350's Avatar
davE350
Lightbulb Tach
I will be putting a tach in my 86 E350. Just the thread I need. Question, where is a good place to install/mount it? Dash? Could any tach work? Or does it need to be specifically for a diesel. I have one of those big Sun tachs for a column mount & a small one if I'd cut a hole for the dash.
Old Mar 15, 2007 | 04:34 PM
Winger235's Avatar
Winger235
Should be near there about the size of a deck of cards.
Old Mar 15, 2007 | 05:53 PM
Dave Sponaugle
The one that hooks up to the alternator is a special tach made to hook up there.
A gasser tach will not work, no ignition to hook it up to on a diesel.
The stock tach in either a gasoline or diesel were not made to hook to the alternator.
Old Mar 16, 2007 | 07:30 AM
bigbubba87's Avatar
bigbubba87
i just put the other 6.9 in my f250 and it didnt have a tach where can i get a one that goes on my alternator or what are other tach ideas?
Old Mar 16, 2007 | 08:09 AM
davE350's Avatar
davE350
Exclamation Tach
Yes BigBubba, that was my next question. Are we talking big bucks for the special application?
Old Mar 16, 2007 | 05:32 PM
Dave Sponaugle
Isspro did have one listed on their website, I have not looked at the site for some time.
www.Isspro.com
I just took a look, they have several listed now.
Old Mar 19, 2007 | 09:48 AM
davE350's Avatar
davE350
www.Isspro.com
Thanks for passing that along Dave!
