92 F-150 4X4 doesn't work
Old Mar 14, 2007 | 09:23 AM
billyzack's Avatar
billyzack
Question 92 F-150 4X4 doesn't work
My 92 F-150 doesn't go into 4 wheel drive when buttons pushed, lights on switch don't go on and no engagemant. I replaced the switch, nothing. Is there a way to check the other components without going to a shop and paying hundreds for something I may be able to diagnose myself? I have a repair book but doesn't address this problem, just says "check control module" and check 5 and 8 pin connectors and again doesn't tell me how. Has anyone had this problem and if so, did you fix it? Thanks in advance, Billyzack
Old Mar 14, 2007 | 10:35 AM
F150xlt's Avatar
F150xlt
I was reading about how the shift motor worked on the Explorer which should be similiar to the F150. It appears if you don't hear the relays click the problem could be the computer. If the relays do click most likely a motor problem.
This link is to a Ford Explorer forum. It has alot of information about how the shift motor works. Seems like the motor is the most common failure. Carbon buildup and a motor stop post that crumbles.
https://www.ford-trucks.com/forums/s....php?p=1102904
Old Mar 14, 2007 | 12:38 PM
Gregorri's Avatar
Gregorri
I second this. When's the last time you had your truck in 4 wheel drive? I had the shift motor on my bronco seize up on me. Pulled it off cleaned up some connections and with a little purswaysion from a hammer, tapping around the outside of the cylinder, its works fine again. I prefer a shifter on the floor now because when you need 4wd, there's no worry about electronics on your tranfer case failing. Also I've gone through some fairly deep water in my bronco and not been able to get out of 4wd because of shift motor fail. Something to keep in mind.
Rick
