headlights 1dim 1 bright?
Old Mar 14, 2007 | 08:40 AM
jerryh20's Avatar
jerryh20
1976 f100 - have left headlight problem - changed headlight switch - changed light - maybe plug needs to be changed - dimmer switch on floor seems ok - any advise appreciated.
Old Mar 14, 2007 | 09:54 AM
arctic y block's Avatar
arctic y block
The ground is bad. I have had to cut the black wire and reground it. Try replacing the socket. Most times this is the problem.
Old Mar 14, 2007 | 01:33 PM
w5kgt's Avatar
w5kgt
Thumbs up Dim headLight
I agree with Arctic Y block,
This is a primary case of a bad ground, or a bad plug/socket. Been there done that.
Kevin
Old Mar 14, 2007 | 04:53 PM
arctic y block
So lets see some pic's of your 76 Kevin. We like Pic's. And welcome to the best site there is to both of you. FTE Rocks
Old Mar 17, 2007 | 03:39 AM
jerryh20's Avatar
jerryh20
dim light solved
advise for fixing problem was followed - turned out to be a ground not connectd after i changed the core support. thanks
Old Mar 17, 2007 | 09:19 AM
arctic y block
Glad ya found the problem
