Still long cold start w/ inductive heating
Old Mar 14, 2007 | 12:34 AM
Bushwhacker's Avatar
Bushwhacker
Let me know what you guys think. I have had issues withn the truck. New turbo. New PCM. New glow plug control module. All have incurred slow cold starting. If I have the truck plugged in it will fire right off. If it is warmed up it will fire right off. Only the initial cold start is the problem. even if it is 60 deg out like it was today. About a 4 sec crank time. The dealership has done an oil pressure check over night and the pressure all held. Supposedly after the new PCM it has the latest flash version 47.8 if that sounds right. I did double check and he says it is the inductive heating flash. Still long crank.
Is it the nature of this beast just to be a long crank on a cold start. I know many of our old International tractors being very cold blooded but I woud think this truck would be better. I love the truck and will be content if that is it's way. But it doesn't seem right and I am sick of bugging the dealership to get no results. They seem to be trying and getting the same result. runs great otherwise.....Any ideas????
Thanks.
Old Mar 14, 2007 | 07:20 AM
cudajim's Avatar
cudajim
So your issue is long cranks, not rough running after starting, correct? The inductive heating flash is for rough running.
My issue with long cranks was when the engine was hot, not cold. Always started when cold.
I would do what I did, changed my oil, and cleaned/replaced the EGR. At the very least, take out the EGR and see what it look like.
Old Mar 14, 2007 | 01:11 PM
Bushwhacker
The truck runs fine after it starts. Yes it is just long crank time when 1rst starting. I thought the inductive flash was for hard cold start and that if there was rough running that was supposed to be fixed prior to inductive flash.....The oil has been changed and the problem didn't change. Would disconnecting the EGR show me anything in terms of the start time?
Old Mar 14, 2007 | 03:42 PM
cudajim's Avatar
cudajim
Flash doesent help with the cranking time. It helps just after the fuel begins to be injected. No more rough running after the engine is started. Things are going on while you are cranking, 500 psi in HPOP is required befor the fuel is injected, ect... What is a long crank to you, my truck can sometimes be 2 seconds.
Old Mar 14, 2007 | 04:06 PM
WishIhada7.3's Avatar
WishIhada7.3
just a stab in the dark but were the actual glow plugs replaced?? if u dont feel like taking it to the dealer or it is out of warranty then u can check em urself with a voltmeter...think of em like a strand of x-mas lights like the old sets if one bulb goes out none work...
Old Mar 14, 2007 | 05:15 PM
18vtx00's Avatar
18vtx00
Smile
none of those things have anything to do w/ it. 4 second crank is normal-
I would only look for a HPO leak or faulty pump. there have been some w/ the oil draining from the HPOP res- due to a small crack in the block-but only on '06+ that I am aware of. We had a brand new 06 w/ bad HPOP for this same concern-it will not bring up pressure for 6-10 seconds of cranking-intermittently- your dealer shoule be able to pinpoin the cause of concern if there is one but like I stated before 4 seconds is normal for a 6.0L. good luck,.
Old Mar 14, 2007 | 05:47 PM
Bushwhacker
The glow plugs were all checked when the module was replaced. All were good....
Old Mar 14, 2007 | 05:48 PM
Bushwhacker
The crank time is usually about 4-5 seconds.
Old Mar 14, 2007 | 05:50 PM
Bushwhacker
The oil did hold pressure and the dealership is telling me this time is normal too. Just didn't seem right to me.
Old Mar 14, 2007 | 06:16 PM
18vtx00's Avatar
18vtx00
Smile
if it is really only 4 seconds then it is normal. I just got my 6.0L about 2 months ago it is normal to all the one i have ever started. but compared to my 7.3L it does crank longer. I would leave it alone- if it was 8+ secs then there would be an issue...
Old Mar 14, 2007 | 10:27 PM
cudajim's Avatar
cudajim
Is it teally 4 seconds, 1, one thousnad, 2, one thousand......
Or are you counting 1, 2, 3, 4
Wow, that is long. I cant beleive that is normal. Something must be wrong.
Wait, you said when its cold, correct, I guess it may be OK.
Old Mar 15, 2007 | 07:54 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Bush, are you running any fuel additives/cetane boost?
Old Mar 16, 2007 | 10:25 AM
Bushwhacker
I haven't actually sat and counted 1 one thousand etc. but I am guessing that if I were to that it would be at least 4 seconds. And yes it is only on 1rst cold start.
Old Mar 16, 2007 | 10:26 AM
Bushwhacker
Yes,
Adding Power Service religiously every tnak. White bottle in the winter.
Old Mar 16, 2007 | 10:32 AM
origcharger's Avatar
origcharger
The following is from an International Service Bulletin which may help explain why 6.0s don't cold start as readily as the 7.3s did;
"DESCRIPTION
In order to meet the 2004 EPA emission regulations many changes to all makes of diesel engines had to be made. These changes were various and included EGR valves, combustion chamber changes as well as others. As a result of these changes the engines do not start as well in cold weather. These characteristics are common with all diesel engines and require manufacturers to approach cold engine starting differently than in the past."
