electrical problem
Old Mar 13, 2007 | 10:26 PM
pj2taylor's Avatar
pj2taylor
electrical problem
I have a 1993 f 150 4wd 302 when i turn the ignition switch off the abs light comes on and will drain the batt. over night. if i pull the fuse for the gauges, intreior light and radio wich are all on one fuse the light goes out and wont drain the batt. i have disconnected all components one at a time and haven been able to find the problem. any suggestions greatly appreciated. thanks. pj
Old Mar 13, 2007 | 11:28 PM
Racerguy's Avatar
Racerguy
Welcome to FTE
I've moved your question to a more appropriate forum for you.
Good luck with it.
