Cavitation!
Old Mar 13, 2007 | 05:08 PM
blake 7.3L's Avatar
blake 7.3L
Cavitation!
Does anyone run a water filter and does it or will it help? Or are there any other methods of prevention that help?
94' f250 7.3L turbo w/ 5spd & 3.55 limited slip
Old Mar 13, 2007 | 05:45 PM
David85's Avatar
David85
Coolant in a diesel engine needs to have SCA added to it, this is designed to prevent cavitation, and it works. Most good quality diesel coolant will already have it mixed in. To check the SCA content in the coolant you can get testing strips from a diesel service shop (like a litmus test). Cavitation is caused by vibration that is unique to the diesel engine (could be other factors as well), so a filter may keep the coolant a little cleaner, but it will have little affect on cavitation.
Old Mar 13, 2007 | 06:13 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
On larger diesels they have a water filter with a sca tablet in the bottom. Sounds like a rock in it when new and dry.
Old Mar 13, 2007 | 06:26 PM
PLC7.3's Avatar
PLC7.3
Back when these engines were built they were SAND cast, like most things the factory cleaning was not sufficient. So after assy they found tons of sand floating around in some engines for years. So a filter system was devised, it works to retain the floating particulates whatever they may be. If you buy the filter they can come with or without a pellet inside to dispurse SCAs over a time period.
This is a kit that fits the PSD, many here have built their own.......
http://www.baldwinfilter.com/engineer/00_1.html
http://www.dieselsitetoo.com/index.asp?PageAction=VIEWPROD&ProdID=443
Old Mar 14, 2007 | 09:24 AM
blake 7.3L's Avatar
blake 7.3L
PLC7.3,
Thanks I think I'll be getting one of these or making my own.
Old Mar 14, 2007 | 10:20 AM
Spectramac's Avatar
Spectramac
Why do you think all those big diesels come with them?
Ford should've put them on all their diesel trucks, not just the big ones.
