Sloppy Rear End
Old Mar 13, 2007 | 04:39 PM
Ol' Stinky's Avatar
Ol' Stinky
Sloppy Rear End
The differential in my F150 has a lot of slack in it when you let off the throttle and then get back into it. With both wheels on the ground there is no slack in the driveshaft. If you raise both rear wheels off the ground you can rotate either wheel a considerable amount before the driveshaft moves. The truck has a Ford nine inch axle in it. It doesn't have any kind of locker or clutch posi unit. What is causing this? There is no whine, howl, or any other noise coming from the axle while under power or coasting.
Old Mar 13, 2007 | 05:09 PM
Franklin2's Avatar
Franklin2
It may be spider gear wear. The 9 inch is easy enough to work on. When you have time I would go ahead and pull it apart and see what the problem really is.
Old Mar 13, 2007 | 07:03 PM
Ol' Stinky's Avatar
Ol' Stinky
Thanks! Would most likely install some sort of locker and a lower gear ratio while it was apart.
dyhrdford
Mar 20, 2012 08:42 AM
SirArgus
1983 - 2012 Ranger & B-Series
Feb 21, 2012 08:01 PM
buck1974
6.4L Power Stroke Diesel
Jul 29, 2010 11:55 AM
chapinmesa
Mar 10, 2009 12:32 PM
no_smoking2003
1997 - 2003 F150
Dec 31, 2004 03:57 PM
