Mini spool from ebay
Old Mar 13, 2007 | 03:18 PM
preppypyro's Avatar
preppypyro
Ebay number 300087520825
Has anyone here used one of these before? Is it close to the same thing that a locker is? I want both of my tires to burn when I step on it in my 89 ford, and looking for a way to keep the stock gears.
Old Mar 15, 2007 | 09:02 AM
Blurry94's Avatar
Blurry94
Bump.
Old Mar 15, 2007 | 10:49 AM
preppypyro's Avatar
preppypyro
Im thinking about just trying to find a limited slip rear end with highway gears to what I have, I did some research and it seems like the mini spool is hard on the rear end.
Old Mar 15, 2007 | 11:07 AM
mudgepondexpress's Avatar
mudgepondexpress
You do NOT want a mini spool. These are popular with the oval track crowd (yes I have installed a couple) where you use different sized tires on each side of the car to make it turn, but it will be horrible anywhere else! This locks the two axles together with no give, thus on each turn one wheel has to "slip" (spin) in order for it to complete the turn. These make the car want to drive straight even when turning. Bad bad bad idea for the street!
Kenny
Old Mar 15, 2007 | 11:10 AM
preppypyro's Avatar
preppypyro
Ok thanks man, good to hear from someone who has used them! Time to look for some LS.
Old Mar 15, 2007 | 01:33 PM
andym's Avatar
andym
Yep, you definitely don't want a minispool or a spool. A detroit locker is the most bulletproof, but replaces the carrier so you need the gears set up again. A powertrax lockright is probably close to what you need.
Edit - that's also for the wrong axle.
47Z-Rod
1947 and Older Ford Trucks
Sep 30, 2013 10:01 PM
delaney
Dec 7, 2006 04:02 PM
Fomoko1
24
Jan 29, 2006 09:01 PM
deadeye
Jul 27, 2002 03:52 PM
