Are these weld-on C's?
Old Mar 13, 2007 | 02:26 AM
460's Avatar
460
Clicky for picture - http://i44.photobucket.com/albums/f2...3-11-07007.jpg
Are these the weld-on style brackets where the radius arm connects to the axle? I can remove these brackets and have a smooth axle tube?
The axle is from a '75 F100. It is a D44 hi-pinion with drum brakes. I can convert this axle to disk brakes using the knuckles, spindles, rotors/hubs, and calipers from a '79 Bronco?
I may use this axle for a SAS into an Explorer. The smooth axle tubes will allow places for welding on the leaf springs perches, and then I need to convert it to disc brakes.
Old Mar 22, 2007 | 02:24 PM
hav24wheel's Avatar
hav24wheel
i'm not sure if anyone answered this question for you yet but i saw you had a couple posts. you can cut off the mounts for the raidius arms from 75 the axle and get a smooth serface with a little grrinder work. and from the balljionts out is what you need to do the disk convertion. the parts off the 79 bronco would work perfect.
ahuggins6
May 29, 2013 12:13 PM
raygussy
May 18, 2007 02:25 PM
460
Offroad & 4x4
Mar 14, 2007 12:48 PM
460
Mar 14, 2007 10:56 AM
