1978 - 1996 Big Bronco
Transmission cooler
Old Mar 12, 2007 | 09:12 PM
b4hntn's Avatar
b4hntn
Transmission cooler
Transmission fluid was leaking from a hose near the bottom of the radiator, passenger side. To my surprise, it connected tubing going to a transmission cooler which I had never noticed in front of condensor coil. From there the fluid goes into the regular cooler in the radiator then back to the transmission. Don't know which way it flows, I'm just happy to know the extra cooler is there and I replaced the hose without the fluid level getting low. I have the towing package so don't know if you have this hose but it might be something to put on your list to replace if you do. A $4 piece of 1/4" X 7" Transmission hose is cheaper than $3,000...
