3.0 and towing
*CHART*
1st gear with the manual is 3.72:1
1st gear with automatic is 2.47:1
1st gear with the manual on the 4.0L is 3.40
i have a 17.5 flats boat, motor, and boat and gear around 1700lbs, my magictilt trailer im not sure how much it weighs but maybe around a k, i have a 4.0 auto 4x4 and due pretty well towing, but florida is pretty much flat so i dont contend with hills just bridges to climb, and she does pretty well.
i was looking in my manual over the weekend it doesnt have my tremor listed but from what im told on here its the "sport", it was funny in the diagram it showed that the fx4 model towes about 300lbs less than what i can tow.
</TD><TD vAlign=top width="24%" bgColor=#333399 colSpan=2>3.0L OHV V-6
</TD><TD vAlign=top width="26%" bgColor=#333399 colSpan=2>4.0L SOHC V-6
</TD></TR><TR><TD vAlign=top width="25%" bgColor=#333399>Gear Ratios
1<SUP nd="62">st</SUP>
</TD><TD vAlign=top width="12%">3.72:1
</TD><TD vAlign=top width="12%">2.47:1
</TD><TD vAlign=top width="13%">3.40:1
</TD><TD vAlign=top width="13%">2.47:1
</TD></TR><TR><TD vAlign=top width="25%" bgColor=#333399>2<SUP nd="70">nd</SUP>
</TD><TD vAlign=top width="12%">2.20:1
</TD><TD vAlign=top width="12%">1.85:1
</TD><TD vAlign=top width="13%">2.05:1
</TD><TD vAlign=top width="13%">1.85:1
</TD></TR><TR><TD vAlign=top width="25%" bgColor=#333399>3<SUP nd="78">rd</SUP>
</TD><TD vAlign=top width="12%">1.50:1
</TD><TD vAlign=top width="12%">1.47:1
</TD><TD vAlign=top width="13%">1.31:1
</TD><TD vAlign=top width="13%">1.47:1
</TD></TR><TR><TD vAlign=top width="25%" bgColor=#333399>4<SUP nd="86">th</SUP>
</TD><TD vAlign=top width="12%">1.00:1
</TD><TD vAlign=top width="13%">1.00:1
</TD></TR><TR><TD vAlign=top width="25%" bgColor=#333399>5<SUP nd="94">th</SUP>
</TD><TD vAlign=top width="12%">0.79:1
</TD><TD vAlign=top width="12%">0.75:1
</TD><TD vAlign=top width="13%">0.79:1
</TD><TD vAlign=top width="13%">0.75:1
</TD></TR><TR><TD vAlign=top width="25%" bgColor=#333399>Reverse
</TD><TD vAlign=top width="12%">3.40:1
</TD><TD vAlign=top width="12%">2.10:1
</TD><TD vAlign=top width="13%">2.10:1
</TD></TR><TR><TD vAlign=top width="25%" bgColor=#333399>Converter
</TD><TD vAlign=top width="12%">-
</TD><TD vAlign=top width="12%">1.80:1
</TD><TD vAlign=top width="13%">-
</TD><TD vAlign=top width="13%">1.80:1
</TD></TR></TBODY></TABLE>
Ok, good for you
. I found the chart showing that the 4.0L manual app. has a 1st gear ratio of 3.40:1. But, if you read the post, rangerguy52 said he had the 3.0 which has a 3.72:1 ratio. But that's besides the point, The manuals have a lower gear ratio throughout the range. This would lead one to think that it should handle higher loads. Bigrigfixer was right on the money. The planetary gear setup in the automatics put more gears(I don't know how many) on the output gears, distributing load through several contact surfaces. Think about it. He's a big rig fixer. The two countershaft setup was a breakthrough for the 'big rig' industry. It reduced weight while preseving load capacity. The torque converter may contribute to the higher loads that automatics can haul, I don't know. But the specs are the specs.
The admin. has chimed in on other threads about advocating overloading the vehicles on highways. He doesn't seem to like it. OK, It'll haul a lot more weight if you run the gear so-so. But be warned, there are two issues that someone has to consider. Safety and mechanical.
Safety- Considering the fact that the max load for a Ranger is just under 6000lbs(depending of course on wether it's a super cab), if you have the 10" brakes on the back and their is no difference in the front disks from model to model, you probably would be able to stop safely on the highway if you follow all precautions, even though it's a manual. The DMV might have a problem if they pull you over for inspection.
Mechanical- According to the manufacturer, you can't overload the vehicle, regardless if you have a manual or automatic transmission. If it's a warranty claim, and they have evidence that it was overloaded(towing company testimony), kiss the claim goodbye. If it's out of warranty, it's up to you whether you want to chance it, mechanically speaking. But again, I don't know what the DMV is like in the states, but in Canada, they will pull your plates and issue a ticket for overloading beyond factory specs. Inspection stops are common these days let alone insurance issues if the worst happens.
For rippin' around the farm, all is good. For towing a 1500lb boat on a 700lb trailer with a 3.0L manual out on the highway? No problem !!!! Have fun with the boat Rangerguy52.
Fred
If you had clearly read my post, you would have seen where I said I meant no offense to bigrigfixr and was merely stating that I prefered manual to auto for towing. Manuals can take it better, they are much less prone to heat damage, easier to fix, and MUCH cheaper should anything ever go wrong that requires complete overhaul or replacement.
It's absolutely stupid to overload any vehicle, auto or manual, no matter what the engine size is. For a properly loaded vehicle however (both in maximum weights and balance), the manual takes the cake for ease of towing larger loads due to it's better gearing, straight through design (no converter), and much less heat output.
For a 1500 lb boat, it hardly matters. With the 3.0L he probably won't notice it's there until he hits the brakes.
it was 90 + out when i pulled that load and i did have to keep an eye on my tranny temp. i have a guage on mine but i think the 1500 should be fine, just dont shift into OD
Matt
Mike
I've towed with both autos and manuals. No comparrison to me - the auto tranny wins hands down.
I'll agree with some others here - at 1500 pounds with your setup, you're good to go. Braking would be my biggest concern.
CMOS
on the clutch, you can actually feel the truck slow down, and the 2000, 3.0 keeps on going smooth no jerking like an automatic, it's this normal or needs repair?
Thanks............
So can someone give me a straight answer of what's safe to tow with a 2000
xtra cab 2wd 3.0L, 5 spd manual, 3 73 axle, I'm not looking for the maximum towing, I don't want to change axle or the trany, so what you guys would recommend if I want to tow a boat taking everything in consideration like towing uphills, back in up pulling from to a boat ramp, etc?
The bumper is rated #2000/200, is this the max total weight for this truck?
A 16 ft fiberglass boat with 100hp motor, how's the truck gonna handle this size boat, again taking in consideration different driving conditions?
Thanks.......................
I have another Q: When towing as much as the bumper limit which is #2000
Do I need to have brakes on the trailer?
Do trailer brakes help when backing or pulling the boat from the ramp? Cuz my truck is a 2wd.
I've been thinking how can you have a #2000 load weight with only #200 tongue? Is there anything that you know weights that much and it has only #200 tongue, that tongue weight looks too light to me for a #2000 load
My '94 manual suggests trailer brakes for any trailer over 1500 lbs. I've towed more than that and never used trailer brakes and haven't had any problems, just planned well ahead.
Trailer brakes won't help you pull away from the ramp...they're exactly what they sound like...brakes on the trailer. They will help you stop, especially if the trailer is well loaded.
I'm not sure of the exact weight of your boat cadriver, but your trailer should have a tag riveted on it somewhere that lists the weight for the trailer, or perhaps that was something my dad's builder did as the trailer was custom made for the boat.
My dad's 18 foot bass boat + 150 hp motor + trailer = 2450 lbs according to that tag.
